1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db'
From: Jeong Han Lee via Tech-talk <[email protected]>
To: Juliane Reinhardt <[email protected]>
Date: Fri, 18 Dec 2020 00:06:13 -0800
Hi Juliane,
Please look at my forked version. Somehow, the calc record is missing,
since my streamDevice was compiled with a calc record. I guess your
stream device may be compiled with a calc record also.
https://github.com/jeonghanlee/lakeshore
I modified its makefile also, but this work is really quick-and-dirty.
I may have more mistakes.
There is another startup script you may see, it is more clean output,
because I remove autosave.
I am sure that SNS will solve this problem more fundamentally soon.
Until then, you may try to see how it works.
HTH,
Han
On Thu, Dec 17, 2020 at 11:14 PM Juliane Reinhardt <[email protected]> wrote:
> Hi Han,
> Thanks for the prompt reply. The repository is here:
> https://github.com/mp49/lakeshore
> Yes I saw these error but then when I looked into the dbd or db files I
> could not see what the actual issue was.
> Juliane
> On 12/17/20 23:11, Jeong Han Lee wrote:
> > Hi Juliane,
> > Your DBD file, example.dbd is wrong. So you have a lot of error
> > message in your IOC startup. Please see below "snip snip section"
> > Since I can get the code of this repository if this is public, could
> > you point me where your repository is?  I cc this email to my lab
> > account.
> > And ALS also has the similar db file, which you may get more benefit
> > from your IOC also.
> > Han
> > --- snip snip ---
> > dbLoadDatabase "dbd/example.dbd"\
> > Declaration of recordtype(scalcout) preceeded full definition.\
> > Error at or before "\}" in file "dbd/example.dbd" line 10293\
> > --- snip snip ---
> > On Thu, Dec 17, 2020 at 9:53 PM Juliane Reinhardt <[email protected]> wrote:
> >> Hi everyone,
> >> Thanks for your help to build the IOC.
> >> I pulled the latest version with the sns specific template removed and
> >> rebuilt the application after modifying the configure/RELEASE file. That
> >> worked fine. However, when starting the IOC I get multiple errors. I
> >> searched for solutions but wasn't successful yet. I would appreciate if
> >> you could point me to some solution as I am still relatively new to
> >> EPICS and with every IOC installation I learn more but only after
> >> running into quite some issues. I attached the output of the ioc startup.
> >> Best,
> >> Juliane
> >> On 12/15/20 07:27, Pearson, Matthew R. wrote:
> >>> Hi,
> >>> Sorry about that. Steve is right, it's just a SNS specific template that shouldn't have been in the example IOC. I've removed the use of devIocStats from the example IOC on GitHub.
> >>> Cheers,
> >>> Matt
> >>>> -----Original Message-----
> >>>> From: Tech-talk <[email protected]> On Behalf Of Hartman,
> >>>> Steven via Tech-talk
> >>>> Sent: Tuesday, December 15, 2020 9:15 AM
> >>>> To: Jeong Han Lee <[email protected]>; Juliane Reinhardt
> >>>> <[email protected]>
> >>>> Cc: tech-talk <[email protected]>
> >>>>> On Dec 15, 2020, at 2:27 AM, Jeong Han Lee via Tech-talk <tech-
> >>>>>    Please look at the example.substitutions file. It uses ioc_sns.db
> >>>>> within there. My first guess ioc_sns.db file is missing or is located
> >>>>> in a wrong directory.
> >>>> ioc_sns.db is a local configuration file for customizing iocStats on the SNS
> >>>> beam lines. It can be safely ignored / commented out.
> >>>> Steven Hartman
> >>>> [email protected]
> >> Juliane Reinhardt, PhD
> >> Project Scientist | ALS Computing Group
> >> Blg. 15-337E | phone: 510-486-4313
> >> [email protected]
> >> Lawrence Berkeley National Lab
> [email protected]
RE: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Pearson, Matthew R. via Tech-talk
lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Hartman, Steven via Tech-talk
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
Prev: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Next: Re: synApps_6_1 build error on windows-x64 with EPICS 7 Markus Huber via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: RE: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Pearson, Matthew R. via Tech-talk
