1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Interfacing HP3458A DMM using LinuxGPIB.
To: Kuldeep Joshi <[email protected]>, "Wang, SuYin Grass" <[email protected]>
Date: Fri, 22 Jan 2021 15:39:26 +0000
Note that the documentation for devGpib (https://epics-modules.github.io/master/asyn/R4-41/devGpib.html) contains this at the top:
NOTE: devGpib is obsolete and should not be used for new applications. StreamDevice<http://epics.web.psi.ch/software/streamdevice> should be used instead.
I would suggesting converting the support to StreamDevice if you plan to do any significant development.
From: Tech-talk <[email protected]> on behalf of Wang, SuYin Grass via Tech-talk <[email protected]>
Sent: Friday, January 22, 2021 9:26 AM
To: [email protected]; Kuldeep Joshi
Hi Kuldeep,
I am using HP3458a recently with BASE:7.0.4 and ASYN:4.40.
This module support is using devGPIB. If you only need the base function, this module is fine.
If you need to add a new function, it could be devGPIB or StreamDevice.
Using devGPIB would need to modify the module and recompile. The learning curve is steeper.
StreamDevice is easier to learn.
Best,
Grass
From: Tech-talk <[email protected]> on behalf of Kuldeep Joshi via Tech-talk <[email protected]>
Sent: Friday, January 22, 2021 4:30 AM
To: [email protected] <[email protected]>
Subject: Interfacing HP3458A DMM using LinuxGPIB.
Hello,
I have to interface HP3458A DMM using Agilent 82357A over LinuxGPIB driver on EPICS 7.
I am able to communicate with the device using the stream module.
I now see a module supporting HP3458A is available. Does this module use the latest ASYN interface libraries? -> http://www.aps.anl.gov/epics/download/modules/hp3458a_cvs.tar.gz
The last modification to this library seems to be in 2004. subsequently I understand there were major changes in how the ASYN interface uses the GPIB bus
Reason I am asking this question is because this HP3458A module has lots of functions and commands incorporated. Which I will have to redo if I use the bare stream interface.
Please suggest me ways to incorporate support for HP3458A in the latest version
Thank you in advance.
Kuldeep
Re: Interfacing HP3458A DMM using LinuxGPIB. Michael Davidsaver via Tech-talk
Interfacing HP3458A DMM using LinuxGPIB. Kuldeep Joshi via Tech-talk
Re: Interfacing HP3458A DMM using LinuxGPIB. Wang, SuYin Grass via Tech-talk
Prev: Re: Interfacing HP3458A DMM using LinuxGPIB. Wang, SuYin Grass via Tech-talk
Next: Re: Strange CAS error Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: Interfacing HP3458A DMM using LinuxGPIB. Michael Davidsaver via Tech-talk
