Subject: Re: Interfacing HP3458A DMM using LinuxGPIB.
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, Kuldeep Joshi <[email protected]>, "Wang, SuYin Grass" <[email protected]>
Date: Fri, 22 Jan 2021 10:05:06 -0800
On 1/22/21 7:39 AM, Mark Rivers via Tech-talk wrote:
> Note that the documentation for devGpib (https://epics-modules.github.io/master/asyn/R4-41/devGpib.html) contains this at the top:
> NOTE: devGpib is obsolete and should not be used for new applications. StreamDevice<http://epics.web.psi.ch/software/streamdevice> should be used instead.
> I would suggesting converting the support to StreamDevice if you plan to do any significant development.
Something basic I did for a test stand at ALS awhile back which might serve as an example.
https://github.com/mdavidsaver/dmm_hp3458a
https://github.com/mdavidsaver/dmm_hp3458a/blob/master/iocBoot/ioctest/st.cmd
https://github.com/mdavidsaver/dmm_hp3458a/blob/master/dmmApp/Db/hp3458a.db
https://github.com/mdavidsaver/dmm_hp3458a/blob/master/dmmApp/protocol/hp3458a.proto
Interfacing HP3458A DMM using LinuxGPIB. Kuldeep Joshi via Tech-talk
Re: Interfacing HP3458A DMM using LinuxGPIB. Wang, SuYin Grass via Tech-talk
Re: Interfacing HP3458A DMM using LinuxGPIB. Mark Rivers via Tech-talk
Prev: Re: Strange CAS error Johnson, Andrew N. via Tech-talk
Next: Re: Strange CAS error Michael Davidsaver via Tech-talk
Prev: Re: Interfacing HP3458A DMM using LinuxGPIB. Mark Rivers via Tech-talk
Next: enabling pvaccess Randall Cayford via Tech-talk
