Subject: Re: combining long strings
From: "Lang, Keenan C. via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: "Sintschuk, Michael" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 4 Feb 2021 00:31:26 +0000
Andrew,
I wasn't before, but I have now changed the errLog function to also write out using errlogPrintf.
Keenan
Sent: Wednesday, February 3, 2021 12:33 PM
To: Lang, Keenan C. <[email protected]>
Cc: Sintschuk, Michael <[email protected]>; [email protected] <[email protected]>
Hi Keenan,
On Feb 3, 2021, at 12:05 PM, Lang, Keenan C. <[email protected]> wrote:
The ERR field has an error in it, so the record did try to process, it just never successfully completed. I haven't seen that error before, but it appears that it points to some sort of issue with invalid memory access during the code execution. I'm trying to track down what went wrong.
Thanks for correcting me, I didn’t notice that PACT was still 1.
Does it also log lua errors using errlogPrintf() or an equivalent? I would want the IOC's error log to have a record of this kind of problem, and to not have to monitor the ERR fields of all the lua records.
- Andrew
Sent: Wednesday, February 3, 2021 12:01 PM
To: Sintschuk, Michael <[email protected]>
Cc: Lang, Keenan C. <[email protected]>; [email protected] <[email protected]>
Hi Michael,
On Feb 3, 2021, at 8:05 AM, Sintschuk, Michael via Tech-talk <[email protected]> wrote:
I like the luascript script solution. But unfortunately it won’t work for me. The record is always in SEVR: invalid mode and there is no input to the AA, BB … fields:
PINI: NO            PJ: 0               PJJ: 0x88d770       PPN: (nil)
PPNR: (nil)         PREC: 0             PRIO: LOW           PROC: 0
PSVL:               PUTF: 0             PVAL: 0             RDES: 0x80c5f0
RELO: Every New File                    RPRO: 0             RPVT: 0x88d570
RSET: 0x7f8e4c1d9e40                    SCAN: Passive       SDIS:CONSTANT
SEVR: INVALID       SPVT: (nil)         STAT: UDF           STATE: 0x88d7a8
SVAL:               SYNC: Sync          TIME: <undefined>   TPRO: 0
TSE: 0              TSEL:CONSTANT       UDF: 1              UDFS: INVALID
VAL: 0              WAIT: NoWait
epics>
Did I missed something with the record settings?
Your record doesn’t appear to have been processed at all yet (STAT is UDF, UDF is 1 and TIME is <undefined>). Does processing it change the result? You can have that happen automatically when the IOC boots by setting PINI to YES, or manually with this iocsh command:
dbpf Topo:FilePath.PROC 1
- Andrew
Complexity comes for free, simplicity you have to work for.
AW: combining long strings Sintschuk, Michael via Tech-talk
Re: combining long strings Lang, Keenan C. via Tech-talk
Re: combining long strings Johnson, Andrew N. via Tech-talk
Prev: RE: PerkinElmer Area Detector on Windows 10 [SEC=OFFICIAL] CORNALL, Terry via Tech-talk
Next: Re: RE: Re: Re: modbus write registers error to Pilz PLC 高振华 via Tech-talk
Prev: Re: combining long strings Johnson, Andrew N. via Tech-talk
Next: AW: combining long strings Sintschuk, Michael via Tech-talk
