1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Creating calc record in Python softioc
From: Jaroslav Adam via Tech-talk <[email protected]>
To: Paul Nord via Tech-talk <[email protected]>
Date: Sat, 6 Feb 2021 23:06:58 -0500 (EST)
Hi Paul,
you may see working example of calc record here:
  https://github.com/star-controls/gasread/blob/master/gasread.py
It is done by a utility function 'make_fm_calc' on line 68,
which is then used in 'gasread_tof' class on lines 61 and 62.
The IPNA and INPB fields are set as record names (string) with
maximize severity MS flag. Forward link FLNK is set from both
inputs.
Hope it helps, cheers,
Jarda
On Fri, 5 Feb 2021, Paul Nord via Tech-talk wrote:
>>> dbpr("XX:CALC",2)
A: 0                ACKS: NO_ALARM      ACKT: YES           ADEL: 0
ASG:                B: 42               BKPT: 00            C: 0
CALC: A*B           D: 0                DESC:               DISA: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DTYP: <nil>
E: 0                EGU:                EVNT: 0             F: 0
FLNK:CONSTANT 0     G: 0                H: 0                HHSV: NO_ALARM
HIGH: 0             HIHI: 0             HOPR: 0             HSV: NO_ALARM
HYST: 0             I: 0                INPA:DB_LINK XX:VALUE NPP NMS
INPB:CONSTANT       INPC:CONSTANT       INPD:CONSTANT       INPE:CONSTANT
INPF:CONSTANT       INPG:CONSTANT       INPH:CONSTANT       INPI:CONSTANT
INPJ:CONSTANT       INPK:CONSTANT       INPL:CONSTANT       J: 0
K: 0                L: 0                LCNT: 0             LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW: 0              LSV: NO_ALARM
MDEL: 0             NAME: XX:CALC       NSEV: NO_ALARM      NSTA: NO_ALARM
PACT: 0             PHAS: 0             PINI: NO            PREC: 0
PRIO: LOW           PUTF: 0             RPRO: 0             SCAN: Passive
SDIS:CONSTANT       SEVR: INVALID       STAT: UDF           TIME: <undefined>
TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 1
VAL: 0
>>> dbpr("XX:VALUE",2)
ACKS: NO_ALARM      ACKT: YES           ADEL: 0             AOFF: 0
ASG:                ASLO: 1             BKPT: 00            DESC:
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DTYP: Python        EGU:                EGUF: 0             EGUL: 0
EOFF: 0             ESLO: 1             EVNT: 0             FLNK:DB_LINK XX:CALC
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV: NO_ALARM       HYST: 0             INP:INST_IO @XX:VALUE
LCNT: 0             LINR: NO CONVERSION LLSV: NO_ALARM      LOLO: 0
LOPR: 0             LOW: 0              LSV: NO_ALARM       MDEL: 0
NAME: XX:VALUE      NSEV: NO_ALARM      NSTA: NO_ALARM      PACT: 0
PHAS: 0             PINI: NO            PREC: 0             PRIO: LOW
PUTF: 0             ROFF: 0             RPRO: 0             RVAL: 0
SCAN: I/O Intr      SDIS:CONSTANT       SEVR: INVALID       SIML:CONSTANT
SIMM: NO            SIMS: NO_ALARM      SIOL:CONSTANT       SMOO: 0
STAT: UDF           SVAL: 0             TIME: <undefined>   TPRO: 0
TSE: 0              TSEL:CONSTANT       UDF: 0              VAL: 7
On Fri, Feb 5, 2021 at 1:48 PM Johnson, Andrew N. <[email protected]> wrote:
      Sounds like you still need a Python softIoc expert then.
It might be helpful if you post the output of
    dbpr("XX:CALC", 2)
and
    dbpr("XX: VALUE", 2)
though so we can see what it sets all the fields to though.
- Andrew
      On Feb 5, 2021, at 1:39 PM, Paul Nord <[email protected]> wrote:
Andrew,
That loads without error.  But the calculation doesn't actually work.
      #!/usr/local/epics/modules/pythonIoc/pythonIoc
from softioc import softioc, builder
builder.SetDeviceName('XX')
rec = builder.aIn('VALUE',VAL=3)
calc = builder.records.calc('CALC', CALC = 'A*B', INPA = rec, B = 42)
rec.FLNK = builder.PP(calc)
#run the ioc
builder.LoadDatabase()
softioc.iocInit()
#start the ioc shell
softioc.interactive_ioc(globals())
      $ caput "XX:VALUE" 7
Old : XX:VALUE                       3
New : XX:VALUE                       7
$ caget "XX:CALC"
XX:CALC                        0
      >> dbpr("XX:CALC")
A: 0                ASG:                B: 42               C: 0
DISP: 0             DISV: 1             E: 0                F: 0
G: 0                H: 0                I: 0                J: 0
K: 0                L: 0                NAME: XX:CALC       SEVR: INVALID
STAT: UDF           TPRO: 0             VAL: 0
On Fri, Feb 5, 2021 at 1:27 PM Johnson, Andrew N. <[email protected]> wrote:
      Hi Paul,
      On Feb 5, 2021, at 12:23 PM, Paul Nord via Tech-talk <[email protected]> wrote:
            According to the documentation, this should work:
                  rec = builder.aIn('VALUE')
                  calc = builder.records.calc('CALC', CALC = 'A*B', A = rec, B = 42)
I’ve never used the Python softIoc, but given this error message
      AssertionError: Can't write "XX:VALUE" to field A: not a number
have you tried this instead?
- Andrew
Complexity comes for free, simplicity you have to work for.
Creating calc record in Python softioc Paul Nord via Tech-talk
Re: Creating calc record in Python softioc Johnson, Andrew N. via Tech-talk
Re: Creating calc record in Python softioc Paul Nord via Tech-talk
Prev: RE: Dynamic user limits in softMotor Mark Rivers via Tech-talk
Next: Re: Re: Re: Re: RE: Re: Re: modbus write registers error to Pilz PLC 高振华 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Creating calc record in Python softioc Paul Nord via Tech-talk
Next: Dynamic user limits in softMotor Laurenz Rettig via Tech-talk
