Subject: RE: Firmware upgrade for MRF event generators and receivers
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: Jeong Han Lee <[email protected]>
Date: Tue, 9 Feb 2021 07:47:05 +0000
Hello Han
We are using the EVG230 and EVR230-RF. There should not be any problem because I used to telnet to the board and dump the memory to check some registers according to the manual.
> Side question, the firmware on MRF website is it for the processor or the FPGA or both? Should I update the processor only or both?
I am starting to think this question explains the problem, because few days ago I just noticed in the manual there is update procedure for the FPGA. So when we say firmware update I am not sure processor, FPGA or both.
Best Regards,
Abdalla.
-----Original Message-----
Sent: Tuesday, February 09, 2021 9:30 AM
To: Abdalla Ahmad <[email protected]>
Cc: Michael Davidsaver <[email protected]>; [email protected]
Subject: Re: Firmware upgrade for MRF event generators and receivers
Hi Abdalla,
Could you explain your hardware model?
I did its firmware update by using MRF software, and epics-modules/mrfioc2 IOC.
Usually, it works without any problem. However, there are some NOT MRF generic firmwares, and NOT MRF hardwares I saw in my life. That is the reason why I made the first question.
Best,
Han
On Mon, Feb 8, 2021 at 10:38 PM Abdalla Ahmad via Tech-talk <[email protected]> wrote:
> Hello Michael
> Thanks for the feedback. Will try to contact MRF.
> Best Regards,
> Abdalla.
> From: Michael Davidsaver <[email protected]>
> Sent: Monday, February 08, 2021 7:32 PM
> Cc: [email protected]
> On 2/8/21 6:37 AM, Abdalla Ahmad via Tech-talk wrote:
> > Hello community
> > This question is not EPICS specific, but I could use some help. We tried downgrading the firmware for spare EVG and EVR boards which have the MRM firmware 005 I think to firmware E403 and D507 respectively. I followed the procedure in the manuals but when I issue the command "u" to start the update process, the telnet session exits with message "Self-programming triggered". I came back after a while and every time I telnet to the board, it seems the device entered a mode where no command is available (only q and x commands), sometimes when the device reboots, I try to dump the memory I get "Addr 0x8000002e: error -1".
> > I tried re-uploading the firmware, power-cycle, and factory settings but nothing works. Any advice how to fix the firmware update process?
> Back when I was at BNL I was able to successfully update firmware on several VME boards (I assume that's what you have).  I was always nervous though.
> I can only recommend contacting MRF.  If you are lucky, and have access to a JTAG programmer, you might be able to directly re-flash the firmware yourself.
Re: Firmware upgrade for MRF event generators and receivers Jeong Han Lee via Tech-talk
Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
Re: Firmware upgrade for MRF event generators and receivers Michael Davidsaver via Tech-talk
RE: Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
Prev: Re: Firmware upgrade for MRF event generators and receivers Jeong Han Lee via Tech-talk
Next: Re: Firmware upgrade for MRF event generators and receivers Jeong Han Lee via Tech-talk
