Hi Abdalla,
On Mon, Feb 8, 2021 at 11:47 PM Abdalla Ahmad
<[email protected]> wrote:
> Hello Han
> We are using the EVG230 and EVR230-RF. There should not be any problem because I used to telnet to the board and dump the memory to check some registers according to the manual.
Still this is unclear to me, but I can assume you have a VME model for
EVG and EVR.
> > Side question, the firmware on MRF website is it for the processor or the FPGA or both? Should I update the processor only or both?
MRF website firmware isn't for VME EVG230 and EVR230-RF, so you should
not use them to update it. From my understanding (not VME), these
firmwares are for FPGA, but I may be wrong, because I don't update any
firmware of VME products.
As Michael mentioned before, it would be better to contact Jukka (MRF)
directly in order to get the real supports from MRF.
HTH,
Han
> I am starting to think this question explains the problem, because few days ago I just noticed in the manual there is update procedure for the FPGA. So when we say firmware update I am not sure processor, FPGA or both.
> Best Regards,
> Abdalla.
> -----Original Message-----
> From: Jeong Han Lee <[email protected]>
> Sent: Tuesday, February 09, 2021 9:30 AM
> To: Abdalla Ahmad <[email protected]>
> Cc: Michael Davidsaver <[email protected]>; [email protected]
> Subject: Re: Firmware upgrade for MRF event generators and receivers
> Hi Abdalla,
> Could you explain your hardware model?
> I did its firmware update by using MRF software, and epics-modules/mrfioc2 IOC.
> Usually, it works without any problem. However, there are some NOT MRF generic firmwares, and NOT MRF hardwares I saw in my life. That is the reason why I made the first question.
> Best,
> Han
> On Mon, Feb 8, 2021 at 10:38 PM Abdalla Ahmad via Tech-talk <[email protected]> wrote:
> > Hello Michael
> > Thanks for the feedback. Will try to contact MRF.
> > Best Regards,
> > Abdalla.
> > From: Michael Davidsaver <[email protected]>
> > Sent: Monday, February 08, 2021 7:32 PM
> > Cc: [email protected]
> > On 2/8/21 6:37 AM, Abdalla Ahmad via Tech-talk wrote:
> > > Hello community
> > > This question is not EPICS specific, but I could use some help. We tried downgrading the firmware for spare EVG and EVR boards which have the MRM firmware 005 I think to firmware E403 and D507 respectively. I followed the procedure in the manuals but when I issue the command "u" to start the update process, the telnet session exits with message "Self-programming triggered". I came back after a while and every time I telnet to the board, it seems the device entered a mode where no command is available (only q and x commands), sometimes when the device reboots, I try to dump the memory I get "Addr 0x8000002e: error -1".
> > > I tried re-uploading the firmware, power-cycle, and factory settings but nothing works. Any advice how to fix the firmware update process?
> > Back when I was at BNL I was able to successfully update firmware on several VME boards (I assume that's what you have). I was always nervous though.
> > I can only recommend contacting MRF. If you are lucky, and have access to a JTAG programmer, you might be able to directly re-flash the firmware yourself.
- RE: Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
- Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
- Re: Firmware upgrade for MRF event generators and receivers Michael Davidsaver via Tech-talk
- Re: Firmware upgrade for MRF event generators and receivers Jeong Han Lee via Tech-talk
Re: caproto ioc alarm value leakage Lauer, Ken via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
