1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: EPID Record
From: Ben Franksen via Tech-talk <[email protected]>
To: <[email protected]>
Date: Sun, 14 Feb 2021 16:42:49 +0100
Am 14.02.21 um 03:18 schrieb Mark Rivers:
> The soft device support contains this code:
>             if (pepid->fbon) {
>                 if (!pepid->fbop) {
>                     /* Feedback just made transition from off to on.  Set the integral
>                        term to the current value of the controlled variable */
>                     if (pepid->outl.type != CONSTANT) {
>                         if (dbGetLink(&pepid->outl,DBR_DOUBLE,&i,0,0)) {
>                             recGblSetSevr(pepid,LINK_ALARM,INVALID_ALARM);
> Whenever feedback make the transition from off to on the value of the
> integral term is set to the current value of the controlled
> variable.
Thanks Mark, I completely missed that. This is very nice.
>  So, for example:
> - Your DAC is set to the value 1.64 V that sets the furnace to 400 C
> - You set the setpoint (.VAL) to 400 C.
> - You turn on feedback.  The integral term (I) will be set to the
> current value of the DAC, 1.64.  This means that turning on feedback
> is "bumpless".> - Now you can change the setpoint to 500 C, and it will use PID to get
there.
> - If you set the VAL to 500 before turning on the feedback it still
> behaves reasonably, since the I term is set to the DAC value for the
> current temperature, 400 C.>
> I apologize that this behavior is not documented.  The documentation
> is clearly very out of date, since it refers to MPF and not to ASYN,
> which is what it currently uses for fast-feedback.>
> Pull requests for documentation updates welcome.
I can't promise anything ATM, but I may give it a try.
Cheers
Ben
I would rather have questions that cannot be answered, than answers that
cannot be questioned.  -- Richard Feynman
Attachment: signature.asc
Description: OpenPGP digital signature
EPICS Record Ben Franksen via Tech-talk
Re: EPID Record Ben Franksen via Tech-talk
Re: EPID Record Mark Rivers via Tech-talk
Re: EPID Record Jemian, Pete R. via Tech-talk
Prev: Re: EPID Record Mark Rivers via Tech-talk
Next: Re: EPID Record Ben Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
