1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: EPICS latest stable version
From: Ben Franksen via Tech-talk <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Thu, 18 Feb 2021 18:30:13 +0100
Am 17.02.21 um 15:08 schrieb Delahaye Olivier via Tech-talk:
> About the upgrade of our EPICS version, I think we could upgrade
> first our linux IOCs without changing for the new pvAcess protocol
> (remaining on Channel Acess protocol).
> In a first step, we can live with 2 different versions of EPICS.
> (3.14 for our IOCs running on VxWorks) and 7.0 for our linux IOCs.
I think nowadays this is probably okay. A year ago I would have
recommended 3.15 but my impression is that 7.0 has matured enough in the
meantime so as to no longer be a moving target.
> In a second step : switch to pvAcess protocol. By the way, even if
> Channel acess is still there, is it still maintained in the same
> manner than pvAcess protocol ?
I won't get any new features, but it is not gpoing to go away any time
soon. AFAIK it will be maintained in the sense of "kept along and fixed
to compile on new archs and compilers" for many years. It is also, and
has been for quite some time, an extremely stable piece of software.
> In a last step and because it's risky, we have to study the impact on
> our oldest VxWorks IOCs. We have quite a lot of drivers running on it
> (epecially for RF part) ant it might not be so easy to switch on 7.0
> version.
My recomendation would be to start doing this in parallel. The EPICS OSI
(OS-independent) API is available since 3.14. Most of what vxWork offers
has a corresponding OSI thing to replace it. For someone who once wrote
an EPICS driver for vxWorks the porting is not too hard. I have done it
for more than 20 drivers/device supports. After the second or third you
won't have much difficulty with the rest, typically, except if they do
something very non-trivial. But of course you need to allow for test time.
> My wish will be to use only linux IOCs but it's another story (need
> to check if all equipments are ready for that, it might request huge
> investments).
As the years go by this is becoming more and more a viable option.
Still, there are some things for which I would say a real real-time
system like RTEMS is still the better choice. For instance, we could
recently improve the behavior of a piece of software I wrote years time
ago (an energy ramp machine, a sequencer state machine plus a host of
records) by moving it from a soft IOC on Linux to an mvme5500 board with
RTEMs. The timing became /a lot/ better, allowing us to ramp faster and
in smaller steps and still with less disturbances.
Cheers
Ben
I would rather have questions that cannot be answered, than answers that
cannot be questioned.  -- Richard Feynman
Attachment: signature.asc
Description: OpenPGP digital signature
EPICS latest stable version Delahaye Olivier via Tech-talk
Re: EPICS latest stable version Kevin Peterson via Tech-talk
Re: EPICS latest stable version Michael Davidsaver via Tech-talk
RE: EPICS latest stable version Delahaye Olivier via Tech-talk
Prev: Re: masarService on Ubuntu 20.04 python3 and Qt5 kunal shroff via Tech-talk
Next: RE: Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: EPICS latest stable version Delahaye Olivier via Tech-talk
Next: Detect PV connect and disconnect events in CSS Pogacnik, Matic via Tech-talk
