Hi Marty and Mark,
Thank you for your quick response.
What Marty suggested makes sense. If the record is processes in INPA,
than of course INPB reads the same value from the Charge record. Thank
you for pointing that out.
However, when I corrected this error as you suggested, the result was
still always 0. Changing the order of NPP before PP should have solved
this problem but it didnt.
Using Marks suggestion of setting B to A after the calculation
("B-A;B:=A") works as expected and yields the correct result. This
solves my problem, but I still dont understand why Marty's suggestion
didnt work.
Thank you,
Donny Domagoj Cosic
Institut Ruđer Bošković, Bijenička cesta 54, 10000 Zagreb, Croatia
Dana 29.03.2021 13:48, Smith, Martin via Tech-talk je napisao(la):
Hi Donny,
Because the Charge record is Passive scan and is being processed
(presumably) only by
the calc record what you are saying makes sense. the calc record
processes the charge
record first for link A using a PP link causing it to get a new
value, then it gets that new
value again using link B without processing (NPP) the charge record.
I think what you really want is this:
record(calc, "$(KEIT):CalcCurrent")
field(SCAN, "1 second")
field(INPA, "$(KEIT):Charge NPP") # Get the current value of Charge
field(INPB, "$(KEIT):Charge PP") # Process charge record then get the
new value
field(CALC, "B-A") # You may need to change this to A-B if you want a
positive value assuming the charge is always increasing
You need to get the current value first then process the record to
get the new value.
Marty
FROM: Tech-talk <[email protected]> on behalf of Donny
Domagoj Cosic via Tech-talk <[email protected]>
SENT: Monday, March 29, 2021 6:35 AM
TO: Tech-talk <[email protected]>
SUBJECT: Rate of change calculation
Hello,
I am trying to calculate the rate of change of a record using a calc
record as follows:
record(ai, "$(KEIT):Charge")
field(DESC, "Measure Charge")
field(DTYP, "steam")
field("@devKeithley6514.proto measureCharge() $(PORT)")
field(SCAN, "Passive")
field(INPA, "$(KEIT):Charge PP")
field(INPB, "$(KEIT):Charge NPP")
field(CALC, "B-A")
The calc record always returns 0. If I change the calc to B+A, to
check
what is going on, I always get double the charge. It seems like the
PP
and NPP are both returning the same value even though the actual
charge
is changing. Any ideas on why this would be happening or suggestions
would be greatly appreciated.
Thank you in advance,
Donny
Donny Domagoj Cosic
Croatia
- Re: Rate of change calculation Pietryla, Tony via Tech-talk
- Rate of change calculation Donny Domagoj Cosic via Tech-talk
- Re: Rate of change calculation Smith, Martin via Tech-talk
Re: Rate of change calculation Mark Rivers via Tech-talk
Re: CS-Studio Databrowser historical data display Kasemir, Kay via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
