Ouch, those are good points I didn't take into account. It might be hard to define one for arrays.
Hi William,
On Mar 30, 2021, at 11:22 AM, William Layne <[email protected]> wrote:
> Unsure if this is still relevant, but I remember there being talk about trying to get channel filters working on put operations. Do you know if that's still being discussed, or even possible? If it is, it could possibly solve this question in the future.
There is no support inside the EPICS 7.0.5 IOC at the moment for running channel filters on puts, and I’m not sure how easy it will be to let filters modify an existing array field instead of just overwriting it with a new value (which is what the existing put API implements).
Another complexity that I see is agreeing on the semantics of what it should mean to run commands like these:
$ caput ‘array1.[4]' 100
$ caput -a ‘array2.[2:3]' 5 1 2 3 4 5
If array1 holds doubles and starts out empty, would the first command set elements 0 through 3 to NaN values, or to zeros? Presumably the second command would leave the first 2 elements of array2 alone, replace elements 2 and 3 with the values 1 and 2, then insert the values 3 4 5 after element 3. Unfortunately implementing these might be tricky without breaking the support for circular buffers that the array field API currently provides.
Thus I wouldn’t hold your breath waiting, although I’m not trying to discourage Ben or Dirk from looking at these kinds of questions.
- Andrew
Complexity comes for free, simplicity you have to work for.
- Questions about arrays Wang, Andrew via Tech-talk
- Re: Questions about arrays Johnson, Andrew N. via Tech-talk
- Re: Questions about arrays William Layne via Tech-talk
RE: Asyn Stopping Transfer Short Iain Marcuson via Tech-talk
Re: Questions about arrays Ben Franksen via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
