Hello community
Indeed i wasnt loading the right expanded .dbd file. I ran makeBaseApp.pl just to make an example IOC that i could compile quickly, then tried to open the .dbd file after compiling and it worked just fine. Thanks so much for the help!
Marco
Hi Marco,
If you define EPICS_DB_INCLUDE_PATH to point to your <EPICS_BASE_FOLDER>/db
it should work fine.
Cheers,
Hugo
On Tue, Apr 6, 2021 at 10:30 AM Johnson, Andrew N. via Tech-talk < [email protected]> wrote:
On Apr 6, 2021, at 10:44 AM, Kyle Hesse wrote:
> Try adding the path to your dbd file in your db file. The link below offers an example under section 6.2.
TBH I don't think that will help, it should be possible to load a DBD file by hand without such a reference in it; if you later save the edited DB file it will get a reference to the DBD file like that included automatically.
> I have downloaded the latest release of VisualDCT via the github link (https://github.com/epics-extensions/VisualDCT/releases) to edit database files via
the interface. When i try to execute the .jar file, a browsing window shows up to let me select a .db or .dbd file but after i select it the window closes and nothing happens. If i try to execute the program via the command java -jar VisualDCT.jar dbdfile.dbd
dbfile.db (the files are in the same directory of the terminal) it generates the following message:
> Loading VisualDCT v2.8.2...
> Directive to load DBD: 'mvc3Include.dbd'.
> Directive to load DB: 'mvc3_channel.db'.
> No DBD loaded! Exiting...
> I suspect its something with my java configurations but im not sure. Does anyone knows if i am doing something wrong? Thanks in advance.
> Obs: i am operating it in a ubuntu 20.04.2 LTS
The fact that you got the “Directive to load” messages indicates that you have almost certainly installed and configured it properly.
I think the problem is that you aren’t loading a fully expanded DBD file. VisualDCT doesn’t know where your EPICS Base installation is, so it can’t use the mvc3Include.dbd file that you’re giving it because that file mostly only contains a list of names of
other DBD files that also need to be loaded. It needs the expanded version, which is probably called mvc3.dbd and should be found in your application’s dbd directory after you have run ‘make’ at least once to build it.
Please try that and let us know if it now works.
- Andrew
Complexity comes for free, simplicity you have to work for.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta
ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying
to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- VisualDCT doesnt load .dbd or .db files Marco A. Barra Montevechi Filho via Tech-talk
- Re: VisualDCT doesnt load .dbd or .db files Kyle Hesse via Tech-talk
- Re: VisualDCT doesnt load .dbd or .db files Johnson, Andrew N. via Tech-talk
- Re: VisualDCT doesnt load .dbd or .db files Hugo Slepicka via Tech-talk
Re: Handling Ethernet-to-Serial Connection when vendor SDK expects tty device Mark Rivers via Tech-talk
Re: phoebus LED in boolean button Hu, Yong via Tech-talk
<2021>
2025
2026
line scan camera with ADAravis driver skips frames Katie Matusik via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
