Subject: Re: Python Script call from Button press, module not found
From: "Kasemir, Kay via Tech-talk" <[email protected]>
Date: Fri, 16 Apr 2021 17:51:52 +0000
Hi:
If the goal is that writing to a PV triggers something in python, wouldn't it be more straight forward to have a python-based CA server?
It serves the "DoIt" PV, and writing to that PV makes the python code do something.
PCASPY, https://pcaspy.readthedocs.io/en/latest/, allows you to implement just that, without need to first create some 'mailbox' IOC for serving the value, then having a script poll/monitor that PV for changes.
With PCASPY you can also support put-callback, so clients writing to the PV can not only trigger whatever you want to happen, but they can also get notified when the action completes.
-Kay
RE: Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
Re: Python Script call from Button press, module not found Kasemir, Kay via Tech-talk
Re: Python Script call from Button press, module not found Matt Newville via Tech-talk
Re: Python Script call from Button press, module not found Johnson, Andrew N. via Tech-talk
Re: Python Script call from Button press, module not found Ben Franksen via Tech-talk
RE: Python Script call from Button press, module not found Layne (US), William C via Tech-talk
Prev: RE: Python Script call from Button press, module not found Layne (US), William C via Tech-talk
Next: Re: WIN_32 Marty Kraimer via Tech-talk
Next: RE: Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
