Am 15.04.21 um 18:46 schrieb Johnson, Andrew N. via Tech-talk:
> On Apr 15, 2021, at 11:26 AM, Manoussakis, Adamandios
> <[email protected]> wrote:
>> I was looking mostly into the epics.camonitor or the auto_monitor
>> parameter (seems like camonitor just when you create the pv you
>> can set this?) in pyepics. The python script is just a small file
>> generator that does some basic calculations. I was trying to have
>> CSS just call it to run to avoid having another application to
>> deal with. Either by pressing a button (execute command works fine
>> but cannot get the execute to trigger based off a rule that I know
>> of) or by a pv changing value and css calling the script (jython
>> doesn’t work with numpy/pandas).
> You might want to take a look at the separate Kryten program
> available from https://github.com/andrewstarritt/kryten which can
> monitor PVs and run specified commands or scripts on conditions
> related to those PVs. Since this wouldn’t be running inside your GUI
> it isn’t subject to the problems related to running multiple
> instances which Michael mentioned.
I recently had a case where I needed that functionality for a simple
test script. I resorted to plain shell scripting, see below. As written
the code works only for a single PV but I guess it wouldn't be hard to
add some filtering / case distinctions in the loop body in case you need
to monitor more PVs.
sel=0
caput BPMMUXCB:sel $sel
camonitor -t n BPMMUXCB:st | while read line; do
st=$(echo -n "$line"|cut -b 33-)
echo "st=$st"
if test $sel = $st; then
sel=$(( ($st + 1) % 32 ))
caput BPMMUXCB:sel $sel >/dev/null
echo "sel=$sel"
fi
done
Ben
I would rather have questions that cannot be answered, than answers that
cannot be questioned. -- Richard Feynman
signature.asc
Description: OpenPGP digital signature
- RE: Python Script call from Button press, module not found Layne (US), William C via Tech-talk
- Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
- Re: Python Script call from Button press, module not found Kasemir, Kay via Tech-talk
- RE: Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
- Re: Python Script call from Button press, module not found Matt Newville via Tech-talk
- Re: Python Script call from Button press, module not found Johnson, Andrew N. via Tech-talk
Re: PVA crossing network segments Hu, Yong via Tech-talk
WIN_32 Marty Kraimer via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
