Just to chime in with a bash function I tend to copy-paste for different scripts. It should work for most PVs with a string representation. (Thanks Ben for the while loop trick! I had to go update mine. It's much cleaner now!)
```sh
function monitor_pv_for_value()
# Function: monitor_pv_for_value
# Description: Template function that executes something when monitored PV matches expected value
# Argument 1: PV name
# Argument 2: Expected value
SEP="$(echo -e "\037")" # Field seperator for camonitor
[ -z "$1" ] && echo "Error: arg 1 must be a PV name" && return 1
[ -z "$2" ] && echo "Error: arg 2 must be value to watch for" && return 2
PV="${1}" # Removes single quote characters as the script quotes them itself
EXPECTED_VAL="$2"
camonitor -t n "$PV" -F "$SEP" | while read line
do
VAL="$(echo -ne "$line" | cut -d "$SEP" -f 3)"
if [[ "${VAL}" == "${EXPECTED_VAL}" ]]
then
# Do something with matching value...
echo "VALUES MATCH"
fi
done
-----Original Message-----
From: Tech-talk [mailto:[email protected]] On Behalf Of Ben
Franksen via Tech-talk
Sent: Friday, April 16, 2021 4:38 AM
To: Johnson, Andrew N. <[email protected]>; Manoussakis, Adamandios
<[email protected]>
Cc: EPICS tech-talk <[email protected]>
Subject: Re: Python Script call from Button press, module not found
Am 15.04.21 um 18:46 schrieb Johnson, Andrew N. via Tech-talk:
> On Apr 15, 2021, at 11:26 AM, Manoussakis, Adamandios
> <[email protected]> wrote:
>> I was looking mostly into the epics.camonitor or the auto_monitor
>> parameter (seems like camonitor just when you create the pv you can
>> set this?) in pyepics. The python script is just a small file
>> generator that does some basic calculations. I was trying to have
>> CSS just call it to run to avoid having another application to deal
>> with. Either by pressing a button (execute command works fine but
>> cannot get the execute to trigger based off a rule that I know
>> of) or by a pv changing value and css calling the script (jython
>> doesn't work with numpy/pandas).
> You might want to take a look at the separate Kryten program available
> from https://github.com/andrewstarritt/kryten which can monitor PVs
> and run specified commands or scripts on conditions related to those
> PVs. Since this wouldn't be running inside your GUI it isn't subject
> to the problems related to running multiple instances which Michael
> mentioned.
I recently had a case where I needed that functionality for a simple test
script. I resorted to plain shell scripting, see below. As written the code
works only for a single PV but I guess it wouldn't be hard to add some
filtering / case distinctions in the loop body in case you need to monitor
more PVs.
sel=0
caput BPMMUXCB:sel $sel
camonitor -t n BPMMUXCB:st | while read line; do
st=$(echo -n "$line"|cut -b 33-)
echo "st=$st"
if test $sel = $st; then
sel=$(( ($st + 1) % 32 ))
caput BPMMUXCB:sel $sel >/dev/null
echo "sel=$sel"
fi
done
Ben
I would rather have questions that cannot be answered, than answers that
cannot be questioned. -- Richard Feynman
- Re: Python Script call from Button press, module not found Kasemir, Kay via Tech-talk
- Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
- RE: Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
- Re: Python Script call from Button press, module not found Matt Newville via Tech-talk
- Re: Python Script call from Button press, module not found Johnson, Andrew N. via Tech-talk
- Re: Python Script call from Button press, module not found Ben Franksen via Tech-talk
RE: WIN_32 Mark Rivers via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
