Subject: Re: asyn bo record staying in INVALID DRIVER UDF
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, Ralph Lange <[email protected]>
Date: Thu, 27 May 2021 17:25:27 +0200
Hej Mark,
good to hear from you.
EPICS base is here:
commit 745d2755f91eb7ae2922f39f5414fdc1e4d45fab (HEAD, tag: R7.0.4)
Author: Andrew Johnson <[email protected]>
Date:   Thu May 28 18:12:51 2020 -0500
And asyn here:
commit 0c70f16c4b27f6717920f40e8c8e0fb2182cac64 (tag: R4-41)
Author: Mark Rivers <[email protected]>
Date:   Sat Sep 19 14:12:11 2020 -0500
    Update release to R4-41
If someone says, please use to the latest, I will update everything.
But until this, I keep it as it is.
/Torsten
On 5/27/21 5:19 PM, Mark Rivers wrote:
I'd like to help understand and/or fix this if it is a problem with asyn.
What versions of base and asyn are you using?
From: Tech-talk <[email protected]> on behalf of Torsten Bögershausen via Tech-talk <[email protected]>
Sent: Thursday, May 27, 2021 9:35 AM
To: Ralph Lange; EPICS Tech Talk
Hej again,
the alaram goes away, if the record is processed one more time.
We don't need to write to the PV, it is enough to disconnect-
and re-connect. Then the asyn callbacks will trigger, and the alarm
goes away.
This code:
IOC:m6-OpenClutchdevAsynInt32.c: static long initBo(boRecord *pr)
      devPvt *pPvt;
      int status;
      epicsInt32 value = 0xFFFFFFFF;
      status = initCommon((dbCommon *)pr,&pr->out,
          processCallbackOutput,interruptCallbackOutput,
interruptCallbackEnumBo,
          2, (char*)&pr->znam, NULL, &pr->zsv);
      fprintf(stdout, "%s/%s:%d %s status=%d\n",
              __FILE__, __FUNCTION__, __LINE__,
              pr->name, (int)status);
      if (status != INIT_OK) return status;
      pPvt = pr->dpvt;
      /* Read the current value from the device */
      status = pasynInt32SyncIO->read(pPvt->pasynUserSync,
                        &value, pPvt->pasynUser->timeout);
      fprintf(stdout, "%s/%s:%d  %s status=%d value=0x%X\n",
              pr->name, (int)status, value);
      if (status == asynSuccess) {
          pr->rval = value;
          return INIT_OK;
      return INIT_DO_NOT_CONVERT;
gives this prints:
../../asyn/devEpics/devAsynInt32.c/initBo:1203 IOC:IOC:m6-OpenClutch
status=0
../../asyn/devEpics/devAsynInt32.c/initBo:1211  IOC:IOC:m6-OpenClutch
status=10 value=0x0
So that the poller() hasn't been able to talk to the controller (yet).
And later, when the callback comes:
static long processBo(boRecord *pr)
      devPvt *pPvt = (devPvt *)pr->dpvt;
      int status;
      fprintf(stdout, "%s/%s:%d %s pPvt->newOutputCallbackValue=%d\n",
              pr->name, pPvt->newOutputCallbackValue);
      epicsMutexLock(pPvt->devPvtLock);
      if(pPvt->newOutputCallbackValue && getCallbackValue(pPvt)) {
          /* We got a callback from the driver */
        fprintf(stdout, "%s/%s:%d %s pPvt->result.status=%d\n",
                pr->name, pPvt->result.status);
          if (pPvt->result.status == asynSuccess) {
              pr->rval = pPvt->result.value;
              pr->val = (pr->rval) ? 1 : 0;
              pr->udf = 0;
../../asyn/devEpics/devAsynInt32.c/processBo:1225 IOC:m6-OpenClutch
pPvt->newOutputCallbackValue=1
../../asyn/devEpics/devAsynInt32.c/processBo:1232 IOC:m6-OpenClutch
pPvt->result.status=0
and here udf is set to zero.
But the alarm stays.
I don't know if this is a possible issue in base, asyn or somewhere else.
BR
/Torsten
On 5/27/21 4:12 PM, Torsten Bögershausen via Tech-talk wrote:
Hej Ralph,
I think it is the same-
camonitor, second round:
IOC:m6-OpenClutch 2021-05-27 15:51:06.243006 Closed UDF INVALID
IOC:m6-OpenClutch.UDF 2021-05-27 15:51:06.243006 0 UDF INVALID
IOC:m6-OpenClutch.STAT 2021-05-27 15:51:06.243006 UDF UDF INVALID
IOC:m6-OpenClutch.SEVR 2021-05-27 15:51:06.243006 INVALID UDF INVALID
[snipped warnings because of multihomed]
And this is dbpr IOC:m6-OpenClutch 10
ACKS: NO_ALARM      ACKT: YES           ASG :               ASP : PTR (nil)
BKLNK: ELL 0 [(nil) .. (nil)]           BKPT: 00            COSV: NO_ALARM
DESC: motor         DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DOL : CONSTANT      DPVT: PTR 0x1030ca0
DSET: PTR 0x7fb1485072c0                DTYP: asynInt32     EVNT:
FLNK: CONSTANT      HIGH: 0             IVOA: Continue normally
IVOV: 0             LALM: 0             LCNT: 0             LSET: PTR
0xf143d0
MASK: 0             MLIS: ELL 4 [0x7fb11802fb38 .. 0x7fb11802fc40]
MLOK: b0 e8 fa 00 00 00 00 00           MLST: 0
NAME: IOC:m6-OpenClutch                  NSEV: NO_ALARM
NSTA: NO_ALARM      OLDSIMM: NO         OMSL: supervisory   ONAM: Open
ORAW: 0             ORBV: 0             OSV : NO_ALARM
OUT : INST_IO @asyn(MCU1,6)OpenClutch   PACT: 0             PHAS: 0
PINI: NO            PPN : PTR (nil)     PPNR: PTR (nil)     PRIO: LOW
PROC: 0             PUTF: 0             RBV : 0             RDES: PTR
0xb6e100
RPRO: 0             RPVT: PTR 0x1030c70 RSET: PTR 0x7fb146f9e860
RVAL: 0             SCAN: Passive       SDIS: CONSTANT      SDLY: -1
SEVR: INVALID       SIML: CONSTANT      SIMM: NO            SIMPVT: PTR
(nil)
SIMS: NO_ALARM      SIOL: CONSTANT      SPVT: PTR (nil)     SSCN: <nil>
STAT: UDF           TIME: 2021-05-27 15:51:06.243005887     TPRO: 0
TSE : 0             TSEL: CONSTANT      UDF : 0             UDFS: INVALID
VAL : 0             WDPT: PTR (nil)     ZNAM: Closed        ZSV : NO_ALARM
/Torsten
On 5/27/21 2:21 PM, Ralph Lange via Tech-talk wrote:
Hi Torsten,
On Thu, 27 May 2021 at 12:53, Torsten Bögershausen via Tech-talk
<[email protected] <mailto:[email protected]>> wrote:
     Asyn-Experts,
     I am chasing an interesting problem.
     For a motor, we have a clutch that can be opened under very
     special conditions, say service mode.
     We define it like this:
     The alarm seem to go away, if the record is processed one more time.
     (by disconnecting the IOC from the controller and re-establishing the
     connection).
     Is this a know phenomena ?
     Anything that can be done ?
How does the setup behave when using Channel Access?
(To see if it is a problem on the ASYN side or the QSRV side of the
database.)
Cheers,
~Ralph
Re: asyn bo record staying in INVALID DRIVER UDF Johnson, Andrew N. via Tech-talk
asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Ralph Lange via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Mark Rivers via Tech-talk
Prev: Re: asyn bo record staying in INVALID DRIVER UDF Mark Rivers via Tech-talk
Next: Re: IOC unusable if no ethernet interface at startup Torsten Bögershausen via Tech-talk
Next: Re: asyn bo record staying in INVALID DRIVER UDF Johnson, Andrew N. via Tech-talk
