1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] caget freezes the bash script
From: "Vodopivec, Klemen via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 31 Aug 2021 18:33:34 +0000
Today the same script failed again. I didn’t see this coming, but Andrew’s comment to try more recent EPICS base actually helped. I’ve made sure to be able to reproduce the problem several times before trying pvget from EPICS 7.0.4.1 - remember, the same script runs fine several times and the randomly stops working, but then once I’m able to get it going once, it will continue to run fine afterwards.
After several attempts with pvget from 4.5 linked against CA from 3.14.12.6, the ’new’ pvget worked out of the box. I’m not sure whether that brings any more information or interest to the subject, since whatever the issue was seems to be solved in latest base. Thank you all for your replies and ideas.
— Klemen
> On Jul 22, 2021, at 5:25 PM, Johnson, Andrew N. <[email protected]> wrote:
> Hi Klemen,
> On Jul 22, 2021, at 2:12 PM, Vodopivec, Klemen via Tech-talk <[email protected]> wrote:
>>> I read
>>> "pvget replaced caget, giving us two implementations that behave the same."
>>> as both "caget" and "pvget -p ca" were used with the same result.
>> Correct, both caget and pvget were tried with the same effect. Both caget and pvget are compiled from the same 3.14.12.6 distribution, pvget is from PVAccess library version 4.5.
> I hate to say this to you, but 3.14.12.6 and EPICS V4 4.5.0 are both 5 years old now. We have fixed some issues in the CA client library since then, although not a huge number, and some problems in the PVA CA Provider interface as well which could be causing this. Thus you’re more likely to get interest from the core developers in helping to resolve the problem if you could use a {ca,pv}get tool from a much more recent EPICS release and demonstrate that the problem still exists (or even better, find that it goes away).
> - Andrew
caget freezes the bash script Vodopivec, Klemen via Tech-talk
Re: caget freezes the bash script J. Lewis Muir via Tech-talk
Re: [EXTERNAL] Re: caget freezes the bash script Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Re: caget freezes the bash script J. Lewis Muir via Tech-talk
Re: [EXTERNAL] caget freezes the bash script Vodopivec, Klemen via Tech-talk
Re: [EXTERNAL] caget freezes the bash script Johnson, Andrew N. via Tech-talk
Prev: Re: synApps 6.1 conflicts with EPICS Base 7.0.6 Pete Jemian via Tech-talk
Next: Re: mbboDirect Bx fields don't update on alarm change Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] caget freezes the bash script Johnson, Andrew N. via Tech-talk
Next: no rpc.h, ALH 网易邮件中心 via Tech-talk
