Subject: Re: [EXTERNAL] Alarm Server and archiveEngine
From: Hasan SANSAR via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>
Cc: [email protected]
Date: Thu, 16 Sep 2021 15:39:12 +0300
Hi Kay,
I'm sorry for previous message. I solved the problem that was easy. I changed "localhost" in kafka/config/server.properties to host ip and I run alarm server with custom configuration with server's ip.
Thanks for your helps.
Hasan
On 16.09.2021 13:08, Hasan SANSAR wrote:
Hi Kay,
For alarms, you can export/import the configuration, but the tools are not compatible at runtime because we moved from RDB+JMS to Kafka.
Thanks for these reference documentations. I can built new archive engine and alarm server from Phoebus source code and so, I built archive engine service and alarm server service.
But there is a problem with alarm server service or maybe with Kafka. Phoebus can connect to alarm server with Accelerator config, but after 30 second, the connection is failed and "No Alarm Server Connection" text appears and my saved messages with key in JSON format in Kafka doesn't appear in Phoebus Alarm UI tools.
And I'm sending the command for messages and I attached outputs of Zookeeper, Kafka and Phoebus (outputKafka.txt, outputZooKeeper.txt, outputPhoebus.txt).
commands for messages:
$ echo 'config:/Accelerator/Vacuum/TARLA:deneme,{"user":"osiloskop", "host":"alarm_server", "description"="deneme", "delay"=2, "count"=2}' | kafka/bin/kafka-console-producer.sh --broker-list 192.168.56.10:9092 --topic Accelerator --property parse.key=true --property key.separator=,
$ kafka/bin/kafka-console-consumer.sh --bootstrap-server 192.168.56.10:9092 --topic Accelerator --from-beginning --property print.key=true --property key.separator=,
Hasan Sansar
Hasan Sansar
Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
Re: [EXTERNAL] Alarm Server and archiveEngine Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
Prev: Re: [EXTERNAL] Alarm Server and archiveEngine Hasan SANSAR via Tech-talk
Next: socketcan driver and the tudsocketcan 曹彪 via Tech-talk
Next: SynApps sscan record: timestamp issue for BUSY DATA and EXSC fields; causing problem archiving with Phoebus Archive engine Kuldeep Joshi via Tech-talk
