I think the performance requirements for a Blackfly S are too high for a simple Raspberry Pi 3? are there any slow, standard cameras that could work with EPICS?
Am 06.10.2021 um 14:05 schrieb Mark
Rivers:
are all products from FLIR supportedYes, they are all GenICam compliant and can be used with either the ADAravis (Linux) or ADSpinnaker (Linux and Windows) drivers in areaDetector. I would suggest the Blackfly S models, which are available in both USB 3.0 and GigE versions. Mark ________________________________ From: William Kirstaedter <[email protected]> Sent: Wednesday, October 6, 2021 6:50 AM To: Mark Rivers Cc: [email protected] Subject: Re: Imaging Source USB Camera thanks, the camera is already here. "old stuff". are all products from FLIR supported ? - W [cid:[email protected]] William Kirstaedter (PP&B) Fritz-Haber-Institut der MPG Faradayweg 4-6 14195 Berlin Tel: 030 8413 5405 Mail: [email protected]<mailto:[email protected]> Am 06.10.2021 um 13:44 schrieb Mark Rivers: Hi William, There is no mention on their Web site that the camera is GenICam compliant. If it were then you could use ADAravis on Linux. It appears that their software library only works on Windows. Do you already have this camera, and if so it there any reason it could not be replaced with another one? You could replace it for less than $400 with a much better performance FLIR camera. That is much less than the cost of writing an EPICS driver for an unsupported camera. Mark ________________________________ From: Tech-talk <[email protected]><mailto:[email protected]> on behalf of William Kirstaedter via Tech-talk <[email protected]><mailto:[email protected]> Sent: Wednesday, October 6, 2021 6:22 AM To: EPICS tech-talk Subject: Imaging Source USB Camera Hi, just wanted to check; has anyone already integrated the following camera into EPICS ? "Imaging Source DMK 41AU02" its a simple greyscale USB 2.0 Camera. there is a C library available: https://www.theimagingsource.com/products/industrial-cameras/usb-2.0-monochrome/dmk41au02/ any thoughts about this thing? -- [cid:[email protected]] William Kirstaedter (PP&B) Fritz-Haber-Institut der MPG Faradayweg 4-6 14195 Berlin Tel: 030 8413 5405 Mail: [email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
