Subject: Re: Imaging Source USB Camera
To: William Kirstaedter <[email protected]>
Date: Wed, 6 Oct 2021 15:26:45 +0000
Hi William,
> I think the performance requirements for a Blackfly S are too high for a simple Raspberry Pi 3?
I don't think that should be an issue.  The performance specifications on their Web site are just the maximum frame rate that the cameras support.  But you can control the frame rate to be the same or slower than your existing USB 2.0 camera, so the performance requirements are the same.  In my experience you can even run their USB 3.0 cameras on a USB 2.0 port, and are just limited in the maximum frame rate.
Sent: Wednesday, October 6, 2021 9:54 AM
To: Mark Rivers
Cc: [email protected]
are there any slow, standard cameras that could work with EPICS?
[cid:[email protected]]
William Kirstaedter (PP&B)      Fritz-Haber-Institut der MPG
Faradayweg 4-6  14195 Berlin
Tel: 030 8413 5405      Mail: [email protected]<mailto:[email protected]>
Am 06.10.2021 um 14:05 schrieb Mark Rivers:
are all products from FLIR supported
Yes, they are all GenICam compliant and can be used with either the ADAravis (Linux) or ADSpinnaker (Linux and Windows) drivers in areaDetector.  I would suggest the Blackfly S models, which are available in both USB 3.0 and GigE versions.
From: William Kirstaedter <[email protected]><mailto:[email protected]>
Sent: Wednesday, October 6, 2021 6:50 AM
To: Mark Rivers
Cc: [email protected]<mailto:[email protected]>
thanks,
the camera is already here. "old stuff".
are all products from FLIR supported ?
- W
Tel: 030 8413 5405      Mail: [email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>
Am 06.10.2021 um 13:44 schrieb Mark Rivers:
Hi William,
There is no mention on their Web site that the camera is GenICam compliant.  If it were then you could use ADAravis on Linux.  It appears that their software library only works on Windows.
Do you already have this camera, and if so it there any reason it could not be replaced with another one?  You could replace it for less than $400 with a much better performance FLIR camera.  That is much less than the cost of writing an EPICS driver for an unsupported camera.
From: Tech-talk <[email protected]><mailto:[email protected]><mailto:[email protected]><mailto:[email protected]> on behalf of William Kirstaedter via Tech-talk <[email protected]><mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>
Sent: Wednesday, October 6, 2021 6:22 AM
To: EPICS tech-talk
Subject: Imaging Source USB Camera
just wanted to check;
has anyone already integrated the following camera into EPICS ?
"Imaging Source DMK 41AU02"
its a simple greyscale USB 2.0 Camera.
there is a C library available: https://www.theimagingsource.com/products/industrial-cameras/usb-2.0-monochrome/dmk41au02/
any thoughts about this thing?
Tel: 030 8413 5405      Mail: [email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]><mailto:[email protected]><mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>
PNG image
Re: Imaging Source USB Camera William Kirstaedter via Tech-talk
Re: Imaging Source USB Camera Mark Rivers via Tech-talk
Prev: Re: iocStats module on RTEMS-5 Johnson, Andrew N. via Tech-talk
Next: RE: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Shankar, Murali via Tech-talk
Prev: Re: Imaging Source USB Camera Wlodek, Jakub via Tech-talk
Next: Re: Imaging Source USB Camera William Kirstaedter via Tech-talk
