Subject: Re: Imaging Source USB Camera
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, William Kirstaedter <[email protected]>
Date: Wed, 6 Oct 2021 14:58:38 +0000
Hi William,
You can use the ADUVC driver to use a typical USB webcam with EPICS/areaDetector. Any device that supports the UVC protocl would work, here are some examples:
I have used this driver with raspberry Pi devices in the past.
It's even possible that your original camera would work, although I am not sure if it uses the UVC protocol. It may be worth asking the vendor if that is supported.
Best,
Jakub
From: Tech-talk <[email protected]> on behalf of William Kirstaedter via Tech-talk <[email protected]>
Sent: Wednesday, October 6, 2021 10:54 AM
Cc: [email protected] <[email protected]>
I think the performance requirements for a Blackfly S are too high for a simple Raspberry Pi 3?
are there any slow, standard cameras that could work with EPICS?
William Kirstaedter (PP&B) Fritz-Haber-Institut der MPG
Faradayweg 4-6 14195 Berlin
Tel: 030 8413 5405 Mail: [email protected]
Am 06.10.2021 um 14:05 schrieb Mark Rivers:
are all products from FLIR supported
Yes, they are all GenICam compliant and can be used with either the ADAravis (Linux) or ADSpinnaker (Linux and Windows) drivers in areaDetector.  I would suggest the Blackfly S models, which are available in both USB 3.0 and GigE versions.
Sent: Wednesday, October 6, 2021 6:50 AM
To: Mark Rivers
thanks,
the camera is already here. "old stuff".
are all products from FLIR supported ?
- W
[cid:[email protected]]
Tel: 030 8413 5405      Mail: [email protected]<mailto:[email protected]>
Am 06.10.2021 um 13:44 schrieb Mark Rivers:
Hi William,
There is no mention on their Web site that the camera is GenICam compliant.  If it were then you could use ADAravis on Linux.  It appears that their software library only works on Windows.
Do you already have this camera, and if so it there any reason it could not be replaced with another one?  You could replace it for less than $400 with a much better performance FLIR camera.  That is much less than the cost of writing an EPICS driver for an unsupported camera.
From: Tech-talk <[email protected]><mailto:[email protected]> on behalf of William Kirstaedter via Tech-talk <[email protected]><mailto:[email protected]>
Sent: Wednesday, October 6, 2021 6:22 AM
To: EPICS tech-talk
Subject: Imaging Source USB Camera
just wanted to check;
has anyone already integrated the following camera into EPICS ?
"Imaging Source DMK 41AU02"
its a simple greyscale USB 2.0 Camera.
there is a C library available: https://www.theimagingsource.com/products/industrial-cameras/usb-2.0-monochrome/dmk41au02/
any thoughts about this thing?
Tel: 030 8413 5405      Mail: [email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>
Imaging Source USB Camera William Kirstaedter via Tech-talk
Re: Imaging Source USB Camera Mark Rivers via Tech-talk
Re: Imaging Source USB Camera William Kirstaedter via Tech-talk
Prev: Re: Imaging Source USB Camera William Kirstaedter via Tech-talk
Next: Re: iocStats module on RTEMS-5 Johnson, Andrew N. via Tech-talk
Next: Re: Imaging Source USB Camera Mark Rivers via Tech-talk
