Subject: Re: "rpcgen: Command not found" When asyn
From: Matt Clarke via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Thu, 14 Oct 2021 06:18:18 +0000
Actually the command might be:
yum --enablerepo=PowerTools install rpcgen
Matt
From: Tech-talk <[email protected]> on behalf of Matt Clarke via Tech-talk <[email protected]>
Reply-To: Matt Clarke <[email protected]>
Date: Thursday, 14 October 2021 at 08:17
Hi.
I think on Centos 8 you need to install rpcgen separately as it is not included in glib.
I.e. yum install rpcgen
You might also need to install libtirpc-devel.
Cheers,
Matt
From: Tech-talk <[email protected]> on behalf of 网易件中心 via Tech-talk <[email protected]>
Reply-To:
网易件中心 <[email protected]>
Date: Thursday, 14 October 2021 at 06:56
Subject: "rpcgen: Command not found" When asyn
Hi all,
    I use centos 8(64), base7.0.6.1,asyn from the github( https://github.com/epics-modules  )
    When I make tha asyn module, I met the question.
make[2]: Entering directory '/home/liangyx/synApps/support/asyn-master/asyn/O.linux-x86_64'
cp ../vxi11/vxi11intr.rpcl .
rpcgen  vxi11intr.rpcl
make[2]: rpcgen: Command not found
cp ../vxi11/vxi11core.rpcl .
rpcgen  vxi11core.rpcl
make[2]: *** No rule to make target 'vxi11core_xdr.c', needed by 'vxi11core_xdr.o'.  Stop.
make[2]: Leaving directory '/home/liangyx/synApps/support/asyn-master/asyn/O.linux-x86_64'
make[1]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/liangyx/synApps/support/asyn-master/asyn'
make: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: asyn.install] Error 2
I have tried "yum install glibc-utils and yum install glibc."       Neither worked.
How I could fix it?
Thanks
Liang
"rpcgen: Command not found" When asyn 网易邮件中心 via Tech-talk
Re: "rpcgen: Command not found" When asyn Matt Clarke via Tech-talk
Prev: Re: "rpcgen: Command not found" When asyn Matt Clarke via Tech-talk
Next: Re: Periodically calling shell functions in an IOC Ralph Lange via Tech-talk
Next: Fwd: "rpcgen: Command not found" When asyn Han Lee via Tech-talk
