1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Start IOC automatically at boot
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 07 Jan 2022 21:57:44 +0100
Hi Ralph,
Thank you for bringing this to my attention. It looks like a very nice solution. Being relatively new to epics, I sometimes get lost in the TechTalk discussions.
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
Dana 07.01.2022 09:37, Ralph Lange via Tech-talk je napisao(la):
On Fri, 7 Jan 2022 at 00:15, Hu, Yong via Tech-talk
<[email protected]> wrote:
As long as you use “sudo manage-iocs start myIOC” to start your
IOC and “sudo manage-iocs stop myIOC” to stop your IOC, the
Python process "python your-python-file.py" should be automatically
terminated when the IOC is stopped.
I wouldn't regard such a setup as robust enough for production use.
You might also want to look at solutions like pyDevSup [1] which can
run Python code *inside* your IOC - at least that was a promising
answer when the original question was discussed on TechTalk in 2019
[2].
(Yes, TechTalk has a search function, and I used it to find that
link.)
Cheers,
~Ralph
[1] http://mdavidsaver.github.io/pyDevSup/ [1]
[2] https://epics.anl.gov/tech-talk/2019/msg01678.php [2]
Links:
Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
RE: Start IOC automatically at boot GAGET Alexis via Tech-talk
Re: Start IOC automatically at boot Hu, Yong via Tech-talk
Re: Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
Re: Start IOC automatically at boot Ralph Lange via Tech-talk
Prev: Re: Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
Next: Re: motor record startup Mooney, Tim M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Start IOC automatically at boot Ralph Lange via Tech-talk
Next: Re: Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
