1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: Re: Phoebus-olog integration
From: "Larregui, Julian via Tech-talk" <tech-talk at aps.anl.gov>
To: "Larregui, Julian via Tech-talk" <tech-talk at aps.anl.gov>
Date: Tue, 1 Feb 2022 18:40:31 +0000
Hello,
Thank you for the assistance, that was the issue at hand. I went ahead and got another build of phoebus which worked. Log creation is successful. The only odd thing is the log entry table. When searching for logs I get an error reporting no entry is found.
Reading the API doc it should be: GET http://localhost:8080/Olog/logs?<query-data>
Any way to change that?
Thank you,
Sent: Monday, January 31, 2022 1:35 PM
To: Larregui, Julian via Tech-talk <tech-talk at aps.anl.gov>; Larregui, Julian <larregui1 at llnl.gov>
> WARNING [org.phoebus.ui.application.PhoebusApplication] Undefined logbook factory olog-es
Different sites use different logbooks.
Did you build CS-Studio with support for the OLog? Or did you use a pre-built version from a site that uses the OLog?
In that case, the ..../lib folder of the product should contain a file app-logbook-olog-client-*.jar
If you downloaded a pre-built binary from the SNS, where you don't use the OLog, that won't be there, and that would explain why the olog-es is unknown.
-Kay
Phoebus-olog integration Larregui, Julian via Tech-talk
Re: Phoebus-olog integration Juan F. Esteban Müller via Tech-talk
Re: Phoebus-olog integration Larregui, Julian via Tech-talk
Re: Phoebus-olog integration Kasemir, Kay via Tech-talk
Prev: A Tribute to our Colleague Marty Kraimer Rolf Keitel via Tech-talk
Next: Conda package for MEDM Thomas, Patrick via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Prev: Re: Phoebus-olog integration Kasemir, Kay via Tech-talk
Next: motor record field assignment problem 高振华 via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
