It looks like you have two problems. This
2022/03/02 09:17:16.451 SERIALPORT -1 autoConnect could not connect: /dev/ttyACM0 Can't open No such file or directory
suggests the given serial port is wrong or the device is not connected.
This
2022/03/02 09:17:16.955732 _main_ Can't find readable file 'arduino.proto' in 'helloWorldIOCApp/Db'
and the next few lines are because it can't find the protocol definitions. Did you create /home/pi/Apps/epics/helloWorldIOC/iocBoot/iochelloWorldIOC/helloWorldIOCApp/Db/arduino.proto
with the given code snippet and does it have the correct permissions?
Hello,
I am currently following a project from the site mentioned below.
I have successfully done the previous mentioned steps. Also a point to note that i am using a virtual machine as i could not install linux on my desktop.
The error that i am facing is:
#!../../bin/linux-x86/helloWorldIOC
## You may have to change helloWorldIOC to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iochelloWorldIOC")
epicsEnvSet("TOP","/home/pi/Apps/epics/helloWorldIOC")
epicsEnvSet("ASYN","/usr/local/epics/modules/asyn")
epicsEnvSet("STREAM","/usr/local/epics/modules/stream")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
epicsEnvSet(STREAM_PROTOCOL_PATH,"helloWorldIOCApp/Db")
cd "/home/pi/Apps/epics/helloWorldIOC"
dbLoadDatabase "dbd/helloWorldIOC.dbd"
helloWorldIOC_registerRecordDeviceDriver pdbbase
drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyACM0",0,0,0)
asynSetOption("SERIALPORT",-1,"baud","115200")
asynSetOption("SERIALPORT",-1,"bits","8")
asynSetOption("SERIALPORT",-1,"parity","none")
asynSetOption("SERIALPORT",-1,"stop","1")
asynSetOption("SERIALPORT",-1,"clocal","Y")
asynSetOption("SERIALPORT",-1,"crtscts","N")
dbLoadRecords("db/arduino.db","PORT='SERIALPORT'")
## Load record instances
#dbLoadRecords("db/xxx.db","user=piHost")
cd "/home/pi/Apps/epics/helloWorldIOC/iocBoot/iochelloWorldIOC"
iocInit
Starting iocInit
## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Feb 21 2022
2022/03/02 09:17:16.955804 _main_ while reading protocol 'get_analog' for 'photo:get'
2022/03/02 09:17:16.955832 _main_ photo:get: Protocol parse error
2022/03/02 09:17:16.955858 _main_ photo:get: Record initialization failed
2022/03/02 09:17:16.955919 _main_ Can't find readable file 'arduino.proto' in 'helloWorldIOCApp/Db'
2022/03/02 09:17:16.955950 _main_ while reading protocol 'set_digital' for 'led:set'
2022/03/02 09:17:16.955979 _main_ led:set: Protocol parse error
2022/03/02 09:17:16.956005 _main_ led:set: Record initialization failed
Bad init_rec return value PV: led:set ao: init_record
## Start any sequence programs
#seq sncxxx,"user=piHost"
epics> 2022/03/02 09:17:17.960955 scan0.5 photo:get: Record not initialised correctly
2022/03/02 09:17:18.457259 scan0.5 photo:get: Record not initialised correctly
2022/03/02 09:17:18.957321 scan0.5 photo:get: Record not initialised correctly
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
