1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: ADViewer, EPICS_NTNDA_Viewer.java compilation
From: Tomasz Brys via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "J. Lewis Muir" <[email protected]>
Date: Fri, 25 Mar 2022 15:53:58 +0000
Yes, I confirm
It works from inside ~/.imagej/plugins.
In my script I can simply change the path and compile from there.
Thanks a lot!
/Tomasz
Date: Friday, 25 March 2022 w:12 at 16:41
To: "J. Lewis Muir" <[email protected]>
Cc: "[email protected]" <[email protected]>, Tomasz Brys <[email protected]>
Hi Lewis,
Thanks, that worked.  I used the relative path to ij.jar and it compiled with no problem from inside the ImageJ/plugins/EPICS_areaDetector directory.
javac -cp ".:jna-5.1.0.jar:epics-ntypes-0.3.5.jar:epics-pvaccess-5.1.5.jar:epics-pvaclient-4.3.2.jar:epics-pvdata-6.1.5.jar:../../ij.jar" ByteBufferUtil.java NTNDCodec.java EPICS_NTNDA_Viewer.java
Sent: Friday, March 25, 2022 10:11 AM
Cc: [email protected] <[email protected]>; Tomasz Brys <[email protected]>
On 03/25, Mark Rivers via Tech-talk wrote:
> Hi Tomasz,
> I am a Java novice, but I got the compilation to almost work by running in the ImageJplugins/EPICS_areaDetector directory:
> corvette:ImageJ/plugins/EPICS_areaDetector>java -cp jca-2.4.5.jar:epics-ntypes-0.3.5.jar:epics-pvaccess-5.1.5.jar:epics-pvdata-6.1.5.jar:epics-pvaclient-4.3.2.jar:epics-util-1.0.3.jar:../../ij.jar EPICS_NTNDA_Viewer.java
> EPICS_NTNDA_Viewer.java:112: error: cannot find symbol
>     private NTNDCodec ntndCodec = null;
>   symbol:   class NTNDCodec
>   location: class EPICS_NTNDA_Viewer
> EPICS_NTNDA_Viewer.java:408: error: cannot find symbol
>                 ntndCodec = new NTNDCodec();
> 2 errors
> error: compilation failed
> It is only complaining that it can't find NTNDCodec.  That is also provide as source code, NTNDCodec.java.  When I try to compile that I get this error:
> corvette:ImageJ/plugins/EPICS_areaDetector>java -cp jca-2.4.5.jar:epics-ntypes-0.3.5.jar:epics-pvaccess-5.1.5.jar:epics-pvdata-6.1.5.jar:epics-pvaclient-4.3.2.jar:epics-util-1.0.3.jar:../../ij.jar NTNDCodec.java
> NTNDCodec.java:29: error: package com.sun.jna does not exist
> import com.sun.jna.NativeLong;
> I don't remember how to fix that, but it is probably straightforward.
> Mark
Hi, Mark and Tomasz!
With ij.jar at /usr/share/java/ij.jar and the master branch of
ADViewers, this should work:
$ cd ADViewers/ImageJ/EPICS_areaDetector
$ ij_jar=/usr/share/java/ij.jar
$ javac -cp ".:jna-5.1.0.jar:epics-ntypes-0.3.5.jar:epics-pvaccess-5.1.5.jar:epics-pvaclient-4.3.2.jar:epics-pvdata-6.1.5.jar:$ij_jar" ByteBufferUtil.java NTNDCodec.java EPICS_NTNDA_Viewer.java
Lewis
ADViewer, EPICS_NTNDA_Viewer.java compilation Tomasz Brys via Tech-talk
Re: ADViewer, EPICS_NTNDA_Viewer.java compilation Mark Rivers via Tech-talk
Re: ADViewer, EPICS_NTNDA_Viewer.java compilation J. Lewis Muir via Tech-talk
Prev: Re: ADViewer, EPICS_NTNDA_Viewer.java compilation Mark Rivers via Tech-talk
Next: phoebus 4.6.6 in windows can't start editor Lee L. Yang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
