1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Driver for Symetrie hexapods?
From: Torsten Bögershausen via Tech-talk <[email protected]>
Date: Fri, 15 Apr 2022 08:14:40 +0200
Hej Mark, Gary, Andy,
Sorry if I repeat things that had been written before,
or are obvious and well known.
The original driver for a powerPMAC (the version using a powerPC CPU)
is here:
https://github.com/Observatory-Sciences/powerPMAC
It supports motorRecord support and talks SSH to the PMAC,
with the gpascii program on the PMAC.
That driver could/should be able to talk to axes being part of a coordinate system,
and may be interesting for code readers.
However, that code was integrated into the generic PMAC driver here:
https://github.com/dls-controls/pmac
HTH
/Torsten
> On 14 Apr 2022, at 19:18, Mark Rivers via Tech-talk <[email protected]> wrote:
> Hi Gary,
> Thanks for the reply.  Symetrie has provided me with EPICS support for their hexapods, written by Observatory Sciences.  It works fine, and emulates the Windows controls program that Symetrie provides.  It allows motion in the Cartesian coordinate system, and display of all status information.  It communicates with a high-level server that runs on the PowerPmac in their controller box.
> However, it only provides support for standard EPICS records, not the motor record.  Since some of our applications want to talk to the motor record I plan to add motor record support.  I will either add it to the driver that Observatory Sciences wrote, or as a separate server.
> Thanks,
> Mark
> From: Yendell, Gary (DLSLtd,RAL,LSCI) <[email protected]>
> Sent: Thursday, April 7, 2022 12:00 PM
> To: Andy Foster <[email protected]>; Mark Rivers <[email protected]>
> Cc: [email protected]
> Hi Mark,
> We have Symetrie Breva and Puna hexapods at DLS, which we use this template for: https://github.com/dls-controls/pmac/blob/dls-master/pmacApp/Db/symetrie_hexapod.template
> I am not sure how compatible it will be, but it might be a good starting point at least.
> Cheers,
> Gary
> From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
> Sent: 07 April 2022 14:00
> Cc: [email protected] <[email protected]>
> Hi Andy,
> Thanks, I have heard back from Symetrie and they sent the manual for the EPICS driver.  It uses the PMAC driver you listed, and I believe the PMAC implements the Cartesian coordinates as virtual motors.
> Mark
> From: Andy Foster <[email protected]>
> Sent: Thursday, April 7, 2022 7:40 AM
> Hi Mark,
> This driver should talk to a Power PMAC Clipper:
> but I don't know if you're looking for an extra application on top of that to drive the Hexapod?
> Cheers, Andy
> On Thu, Apr 7, 2022 at 1:22 PM Mark Rivers via Tech-talk <[email protected]> wrote:
> Correction, the hexapod model is the BORA, not BUNA.
> Sent: Thursday, April 7, 2022 7:18 AM
> To: [email protected] <[email protected]>
> Subject: Driver for Symetrie hexapods?
> Folks,
> We just received a Symetrie BUNA hexapod with their NAOS controller.  The controller has a Delta Tau Power PMAC Clipper inside, with their hexapod software.  Does anyone have an EPICS driver for this?
> Thanks,
> Mark
> This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
Driver for Symetrie hexapods? Mark Rivers via Tech-talk
Re: Driver for Symetrie hexapods? Mark Rivers via Tech-talk
Re: Driver for Symetrie hexapods? Andy Foster via Tech-talk
Re: Driver for Symetrie hexapods? Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
RE: Driver for Symetrie hexapods? Mark Rivers via Tech-talk
Prev: RE: Driver for Symetrie hexapods? Mark Rivers via Tech-talk
Next: Re: Can't properly restrict IOC CA server to an interface Jure Varlec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Job opportunities at SNS/ORNL Vodopivec, Klemen via Tech-talk
