I modified my python script to toggle the ao values between -0.5 and 5
and the A32 address is always -0.5:
VME Bus Error accessing A32: 0xbfe00000
machine check
Exception next instruction address: 0x032dc280
Machine Status Register: 0x0008b032
Condition Register: 0x40000844
Task: 0x3576c20 "CAC-event"
0x3576c20 (CAC-event): task 0x3576c20 has had a failure and has been
stopped.
0x3576c20 (CAC-event): The task has been terminated because it triggered
an exception that raised the signal 10.
I can't run the Wind River workbench yet; I'm still waiting on IT to
start the necessary license servers.
My VME has the VMETRO bus analyzer in it, but it has probably been a
decade since I watched someone (Ron Sluiter) use it effectively.
Kevin
On 6/9/22 11:05, Mark Rivers via Tech-talk wrote:
If the test program loops from -0.7 to -0.5 the VME bus error address is
0xbfe66664. That is -0.6999988555908203 when interpreted as a double
with that address as the most significant 32 bits. That is within the
now more restricted range of the output values.
- RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Till Straumann via Tech-talk
Re: Questions for epics 7 PVs: PV list with normative type Michael Davidsaver via Tech-talk
RE: [EXTERNAL] Re: RBV value for Soft Channel motor not always being set properly on IOC startup Gregory, Ray via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
