> I modified my python script to toggle the ao values between -0.5 and 5 and the A32 address is always -0.5:
That makes sense because -0.5 is the only value that maps to the A32 address space. -0.4 to +5.0 do not.
-----Original Message-----
Sent: Thursday, June 9, 2022 12:21 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; Till Straumann <till.straumann at psi.ch>
Cc: tech-talk at aps.anl.gov
Subject: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
VME Bus Error accessing A32: 0xbfe00000
machine check
Exception next instruction address: 0x032dc280 Machine Status Register: 0x0008b032 Condition Register: 0x40000844
Task: 0x3576c20 "CAC-event"
0x3576c20 (CAC-event): task 0x3576c20 has had a failure and has been stopped.
0x3576c20 (CAC-event): The task has been terminated because it triggered an exception that raised the signal 10.
I can't run the Wind River workbench yet; I'm still waiting on IT to start the necessary license servers.
My VME has the VMETRO bus analyzer in it, but it has probably been a decade since I watched someone (Ron Sluiter) use it effectively.
Kevin
On 6/9/22 11:05, Mark Rivers via Tech-talk wrote:
> If the test program loops from -0.7 to -0.5 the VME bus error address
> is 0xbfe66664. That is -0.6999988555908203 when interpreted as a
> double with that address as the most significant 32 bits. That is
> within the now more restricted range of the output values.
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Till Straumann via Tech-talk
- RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Kevin Peterson via Tech-talk
PVStructure vs Structure Madden, Timothy J. via Tech-talk
Re: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Hartman, Steven via Tech-talk
<2022>
2025
<2022>
2025
