1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Multiple pointers to /usr/lib/epics
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 23 Nov 2022 10:07:35 +0100
On Tue, 22 Nov 2022 at 22:33, Daykin, Evan via Tech-talk <[email protected]> wrote:
After upgrading to EPICS 7, we now get the following warning(s) when building packages with multiple dependencies:
>/usr/lib/epics/configure/RULES_BUILD:601: Warning: Base configure/RULES_BUILD file included more than once. Does configure/RELEASE have multiple pointers to /usr/lib/epics?
Our convention is as Mark describes here: https://epics.anl.gov/tech-talk/2021/msg00813.php . Our add-ons are essentially all installed into a flat /usr/lib/epics directory, and our experience is the same as Mark described – as long as any miscellaneous package that is _not_ in /usr/lib/epics is defined before anything that _is_ in /usr/lib/epics, everything works fine. Now that we are getting these warnings, can they be ignored, or is this convention broken/otherwise disfavored in EPICS 7?
Such "flat" installations are fine and supported.
The check for double inclusion is relatively new. It emits a warning, as it doesn't know if the double inclusion is due to a bug or happens because you have multiple modules in a flat installation.
In the latter case, you can safely ignore the warning.
To avoid it, you can try to not define a module in the RELEASE file at all (will work for most modules). If the module or your application use things like 'ífdef $SNCSEQ' in Make rules, not defining it would break and you can try defining it as a string that is not a location, e.g., 'SNCSEQ=installed'.
Cheers,
~Ralph
Multiple pointers to /usr/lib/epics Daykin, Evan via Tech-talk
Prev: EPICS startup script st.cmd on vxWorks warning message whitetiger1123 via Tech-talk
Next: Re: EPICS startup script st.cmd on vxWorks warning message Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Multiple pointers to /usr/lib/epics Daykin, Evan via Tech-talk
Next: Re: Multiple pointers to /usr/lib/epics Michael Davidsaver via Tech-talk
