On 11/23/22 2:40 AM, whitetiger1123 via
Tech-talk wrote:
Hello
all,
While
running EPICS startup script st.cmd on vxWorks for an app that
was made successfully, I am getting following error:
[VxWorks Boot]:
boot
device : geisc
unit
number : 0
processor
number : 0
host
file
inet on
ethernet (e) : 10.4.49.69:ffffff00
host inet
(h) : 10.4.49.170
gateway inet
(g) : 10.4.49.99
user
(u) : test
ftp password
(pw) : test
flags
(f) : 0x0
startup script
(s) :
host:/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd
Loading...
2457184
Starting at
0x100000...
Snipped ...
iocInit
Starting
iocInit
## EPICS
R3.15.6
## EPICS Base
built Oct 7 2022
WARNING: OS
Clock time was read before being set.
Using
1990-01-02 00:00:00.000000 UTC
iocInit: Time
provider has not yet synchronized.
iocRun: All
initialization complete
value = 0 = 0x0
The IOC appears to have started normally so it should work. The only
issue will be that it wasn't able to set its time-of-day clock, so
the timestamps that accompany any data over Channel Access will be
dated from January 1990. Unless you explicitly configure it the
VxWorks clock code in EPICS will try to synchronize the OS clock
time with an NTP server running on the boot host. If your boot host
doesn't run an NTP server such as ntpd or chrony (or the server
isn't configured to make the time available over the network) you
can give the IOC the IP address for another NTP server like this,
replacing xx with the appropriate number for that server:
putenv "EPICS_TS_NTP_INET=10.4.49.xx"
That line should be added near the top of your st.cmd script,
preferably before the line that loads the oms.munch file.
Alternatively you could install an NTP server on your boot host and
make sure that it can be access through any firewall that is running
there, then you won't need the line above.
There are a few commands that you can run to look at the state of
the EPICS time synchronization system: generalTimeReport(1)
will list the time providers that have been registered with it and
what their current state is. NTPTime_Report(1)
will give more information about the NTP time synchronization task,
and ClockTime_Report(1) tells you
about the task that synchronizes the OS clock — both of those should
also appear in the generalTimeReport output but with different
information. You can omit the (1)
parameters to those commands which will then show less detail.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
- EPICS startup script st.cmd on vxWorks warning message whitetiger1123 via Tech-talk
Re: Multiple pointers to /usr/lib/epics Ralph Lange via Tech-talk
Re: Multiple pointers to /usr/lib/epics Michael Davidsaver via Tech-talk
<2022>
2025
2026
Illegal field value PV: oms:m1 motor_init_record_com(): card does not exist! motorOMS st.cmd error whitetiger1123 via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
