Hello all,
While running EPICS startup script st.cmd on vxWorks for an app that was made successfully, I am getting following error:
[VxWorks Boot]: @
boot device : geisc
unit number : 0
processor number : 0
host name : host
file name : /home/test/work2/vxconf/default/vxWorks
inet on ethernet (e) : 10.4.49.69:ffffff00
host inet (h) : 10.4.49.170
gateway inet (g) : 10.4.49.99
user (u) : test
ftp password (pw) : test
flags (f) : 0x0
startup script (s) : host:/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd
Loading... 2457184
Starting at 0x100000...
Target Name: vxTarget
Adding 7851 symbols for standalone.
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks 6.9
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.13
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-2011
CPU: Motorola MVME6100-0173 - MPC 7457. Processor #0.
Memory Size: 0x40000000 (1024Mb). BSP version 6.9/0.
Created: Nov 11 2022, 13:44:33
ED&R Policy Mode: Deployed
WDB Comm Type: WDB_COMM_END
WDB: Agent Disabled.
Executing startup script 'host:/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd'...
## Example vxWorks startup file
## The following is needed if your board support package doesn't at boot time
## automatically cd to the directory containing its startup script
#cd "/home/USERNAME/epics/iocs/omsIOC/iocBoot/iocOms"
cd "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms"
value = 0 = 0x0
< cdCommands
startup = "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms"
New symbol "startup" added to kernel symbol table.
startup = 0x44f7f50: value = 72359072 = 0x4501ca0
putenv("IOC=iocOms")
value = 0 = 0x0
top = "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC"
New symbol "top" added to kernel symbol table.
top = 0x4501c20: value = 72359296 = 0x4501d80 = top + 0x160
putenv("TOP=/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC")
value = 0 = 0x0
topbin = "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/bin/vxWorks-ppc32"
New symbol "topbin" added to kernel symbol table.
topbin = 0x4501ec0: value = 72359696 = 0x4501f10 = topbin + 0x50
motor = "/home/test/epics/synApps_6_1/support/motor-R7-1"
New symbol "motor" added to kernel symbol table.
motor = 0x4501e90: value = 72359856 = 0x4501fb0 = topbin + 0xf0
putenv("MOTOR=/home/test/epics/synApps_6_1/support/motor-R7-1")
value = 0 = 0x0
motorbin = "/home/test/epics/synApps_6_1/support/motor-R7-1/bin/vxWorks-ppc32"
New symbol "motorbin" added to kernel symbol table.
motorbin = 0x44cf4f0: value = 72327040 = 0x44f9f80
asyn = "/home/test/epics/synApps_6_1/support/asyn-R4-36"
New symbol "asyn" added to kernel symbol table.
asyn = 0x44f9fe0: value = 72367504 = 0x4503d90
putenv("ASYN=/home/test/epics/synApps_6_1/support/asyn-R4-36")
value = 0 = 0x0
asynbin = "/home/test/epics/synApps_6_1/support/asyn-R4-36/bin/vxWorks-ppc32"
New symbol "asynbin" added to kernel symbol table.
asynbin = 0x4503e80: value = 72367824 = 0x4503ed0 = asynbin + 0x50
sncseq = "/home/test/epics/synApps_6_1/support/seq-2-2-6"
New symbol "sncseq" added to kernel symbol table.
sncseq = 0x4503f30: value = 72368000 = 0x4503f80 = sncseq + 0x50
putenv("SNCSEQ=/home/test/epics/synApps_6_1/support/seq-2-2-6")
value = 0 = 0x0
sncseqbin = "/home/test/epics/synApps_6_1/support/seq-2-2-6/bin/vxWorks-ppc32"
New symbol "sncseqbin" added to kernel symbol table.
sncseqbin = 0x4503fc0: value = 72364144 = 0x4503070 = 'p'
busy = "/home/test/epics/synApps_6_1/support/busy-R1-7-2"
New symbol "busy" added to kernel symbol table.
busy = 0x44cb710: value = 72364560 = 0x4503210
putenv("BUSY=/home/test/epics/synApps_6_1/support/busy-R1-7-2")
value = 0 = 0x0
busybin = "/home/test/epics/synApps_6_1/support/busy-R1-7-2/bin/vxWorks-ppc32"
New symbol "busybin" added to kernel symbol table.
busybin = 0x4503fe0: value = 72364848 = 0x4503330 = '0'
ipac = "/home/test/epics/synApps_6_1/support/ipac-2-15"
New symbol "ipac" added to kernel symbol table.
ipac = 0x4503390: value = 72365024 = 0x45033e0 = ipac + 0x50
putenv("IPAC=/home/test/epics/synApps_6_1/support/ipac-2-15")
value = 0 = 0x0
epics_base = "/home/test/epics/base-3.15.6"
New symbol "epics_base" added to kernel symbol table.
epics_base = 0x45034b0: value = 72365312 = 0x4503500 = epics_base + 0x50
putenv("EPICS_BASE=/home/test/epics/base-3.15.6")
value = 0 = 0x0
epics_basebin = "/home/test/epics/base-3.15.6/bin/vxWorks-ppc32"
New symbol "epics_basebin" added to kernel symbol table.
epics_basebin = 0x45035d0: value = 72365616 = 0x4503630 = '0' = epics_basebin + 0x60
< ../nfsCommands
#Instructions for creating and using a real nfsCommands file
# in order to use nfs do the following:
# 1) Create hostAdd and nfsMount commands for each nfs server
# 2) In each st.cmd file add the following two commands BEFORE any load commands
# ../nfs.cmd
# cd "<iocname>
# The hostAdd command has the form:
# hostAdd("<host>","xxx.xxx.xxx.xxx")
# The vxWorks nfsMount command has the form:
# nfsMount("<host>")
# You can also mount subdirectories as follows:
# nfsMount("<host>", "/xxx/xxx/xxx", "/xxx")
# For example assume
# host is mercury with inet address 155.77.2.56
# You want to mount the directory (which is a file system of mercury)
# /home/mercury5/iocinfo
# as
# /iocinfo
# The commands would be
# hostAdd("mercury","155.77.2.56")
# nfsMount("mercury","/home/mercury5/iocinfo","/iocinfo")
cd topbin
value = 0 = 0x0
## You may have to change oms to something else
## everywhere it appears in this file
ld 0,0, "oms.munch"
BSP routine sysAtReboot() not found, epicsExit() will not be
called by reboot. For reduced functionality, call
rebootHookAdd(epicsExitCallAtExits)
value = 72413200 = 0x450f010
cd top
value = 0 = 0x0
dbLoadDatabase "dbd/oms.dbd"
value = 0 = 0x0
oms_registerRecordDeviceDriver pdbbase
value = 0 = 0x0
cd startup
value = 0 = 0x0
## motorUtil (allstop & alldone)
dbLoadRecords("$(MOTOR)/db/motorUtil.db", "P=oms:")
value = 0 = 0x0
## Support for the OMS MAXv (VxWorks shell or iocsh)
#< MAXv.cmd
#< MAXv.iocsh
## Support for the OMS VME85
#< VME58.cmd
## Support for the OMS VME8 and VME44
#< VME8.cmd
## Support for the OMS PC68 and PC78 (requires asyn)
#< PC68.cmd
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Oct 7 2022
WARNING: OS Clock time was read before being set.
Using 1990-01-02 00:00:00.000000 UTC
iocInit: Time provider has not yet synchronized.
value = 0 = 0x0
motorUtilInit("oms:")
value = 0 = 0x0
# Boot complete
Done executing startup script 'host:/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd'.
I hope you understand Iam new to the world of EPICS. Casual I’ve been trying to understand them for 3 days. From there to before he knew nothing of them.
I hope you can help.
Thanks and regards.
