1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: How to: IOC reading information from file?
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
To: "Nariyoshi, Pedro" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 28 Nov 2022 20:05:51 +0000
Thanks for the suggestion, Pedro!
At the end of the day, i figured that maybe autosave fdbrestore function would do what i wanted. Unfortunately, the function was resulting in segmentation fault. Looking in tech-talk i found this thread: https://epics.anl.gov/tech-talk/2014/msg01851.php which suggested that for autosave versions before 5.4.1 it is a known bug which is fixed after that. Since im using autosave 5-10-2 and the PVs are not very long, i gave up using autosave for this.
 I am indeed doing something similar to what you suggested: i created a file full of dbpf's and im trying to use the "execute" function of streamDevice to do a protocol file with:
call_file {
        execute "< file_with_dbpfs.cmd";
And a PV in the form:
record(stringout, "$(P)$(R)UpdateConfig"){
    field(DESC, "Filename from which to get values.")
    field(OUT, "@iocsh_functions.proto call_file")
Untill now i had no success but it seems to be some silly mistake that i still didnt have time to debug.
Marco
Sent: 28 November 2022 13:50
To: Marco A. Barra Montevechi Filho <[email protected]>; [email protected] <[email protected]>
Hi Marco,
I don't know if there's a native functionality for this, but for some of our IOCs we use python to do some of these things. You can add something like  "system 'python3 iocApp/py/script.py arguments &'" to the startup script. The script would do a camonitor ' MYRECORD:Output' and have a callback to read the file and do the respective actions. It's not as clean as your original proposition, but it should be faster to get running until you figure something a better solution.
Pedro Nariyoshi
Software Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7352
Email: [email protected]
1633986722804
From: Marco A. Barra Montevechi Filho <[email protected]>
Sent: Thursday, November 24, 2022 10:02 AM
To: [email protected]
Subject: How to: IOC reading information from file?
[EXTERNAL] This email originated from outside of FRIB
Hello all.
I want to create a set of configuration files (probably json, yaml or even txt) that i can make my IOC read and put the values into PVs. I could swear i read something about reading configuration files in EPICS documentation before but i cant for the life of me find it again.
Desired functionality would be something like:
file config0.yaml has: {"my_var" : 0}
file config1.yaml has: {"my_var" : 1}
And then i would have a record, say MYRECORD:Output that when i do:
caput MYRECORD:Output "config0.yaml"
the record would output 0 to its output link. And
caput MYRECORD:Output "config1.yaml"
the record would output 1 to its output link.
Is there any module or record that offers similar functionality?
Thanks in advance,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: How to: IOC reading information from file? Michael Davidsaver via Tech-talk
How to: IOC reading information from file? Marco A. Barra Montevechi Filho via Tech-talk
Re: How to: IOC reading information from file? Nariyoshi, Pedro via Tech-talk
Prev: Re: Using one substitution file for multiple template files Ralph Lange via Tech-talk
Next: Re: How to: IOC reading information from file? Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: How to: IOC reading information from file? Nariyoshi, Pedro via Tech-talk
