1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Dante
From: Andrew Johnson via Tech-talk <[email protected]>
To: "Siddons, David" <[email protected]>, Mark Rivers <[email protected]>
Date: Sun, 20 Aug 2023 19:50:56 -0500
FYI the EPICS_CA_MAX_ARRAY_BYTES setting has been optional since EPICS 3.16.1, so if you're using any EPICS 7.0.x release and haven't explicitly set
EPICS_CA_AUTO_ARRAY_BYTES=NO
somewhere in either your Base build configuration or in your environment the MAX limit shouldn't be something you need to set.
- Andrew
On 8/18/23 7:21 AM, Siddons, David via Tech-talk wrote:
We changed that line in st.cmd. It didn't seem to make a difference at first glance. We'll play more. I would expect an error if the payload exceeded the default EPICS_CA_MAX_ARRAY_BYTES, no?
Pete.
Sent: Thursday, August 17, 2023 11:00 AM
To: Siddons, David <[email protected]>
Cc: [email protected] <[email protected]>
Subject: Re: Dante
You may also need to increase EPICS_CA_MAX_ARRAY_BYTES
Sent from my iPhone
On Aug 17, 2023, at 9:24 AM, D Peter Siddons via Tech-talk <[email protected]> wrote:
The EPICS interface to Dante allows setting the spectrum length to 4096, but the data only ever covers 2048 channels. How do I make it show 4096?
Pete.
D. Peter Siddons
Detector Development Group Leader
Photon Science Division, NSLS-II,
Bldg. 535B
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
Complexity comes for free, Simplicity you have to work for.
Dante D Peter Siddons via Tech-talk
Re: Dante Mark Rivers via Tech-talk
Re: Dante Siddons, David via Tech-talk
Prev: Re: Can we set 'NELM' tobe a variable in waveform or subArray? Mark Rivers via Tech-talk
Next: Re: Problem writing enum entries from asyn driver (areaDetector) ino a databse record. Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Dante Siddons, David via Tech-talk
Next: Re: Dante Mark Rivers via Tech-talk
