1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Beckhoff ADS to EPICS
To: Torsten Bögershausen <[email protected]>
Date: Sun, 26 Nov 2023 23:18:55 +0800 (CST)
Yes, I set up an ADS route on " another Beckhoff PLC " as follows.
First of all  I used BeckhoffADS module (https://github.com/EuropeanSpallationSource/epics-twincat-ads/BeckhoffADS)to test the connected PLC. I set up the new ADS route in the following file in this module.
BeckhoffADS/PLC-TestProject/NotificationTest.tsproj
BeckhoffADS/example/example.cpp
Then I execute make test and the following error occurs.
./example.bin
2023-11-24T19:33:57+0800 Info: Connected to 192.168.3.10
Running step 1
2023-11-24T19:33:57+0800 Error: read frame failed with error: 104
2023-11-24T19:33:57+0800 Info:connection closed by remote
Add device port: 0x851
Add device notification failed with: 1861
Running step 2
notificationByNameExample():
make: *** [test] Broken pipe
What is the cause of this error?
Also, for the IOC, I changed the AmsId and IP of another PLC in the file "startup/adsOnlyIO.cmd".
At 2023-11-24 23:44:55, "Torsten Bögershausen" <[email protected]> wrote:
Hej Lesley,
Did you set up an ADS route on “another Beckhoff PLC “ (towards your IOC ?)
/Torsten
From: Tech-talk <[email protected]> on behalf of Lesley via Tech-talk <[email protected]>
Reply to: Lesley <[email protected]>
Date: Friday, 24 November 2023 at 16:21
Subject: Beckhoff ADS to EPICS
Hello!
I previously used the EPICS Module to communicate with TwinCAT controllers over ADS protocol (https://github.com/EuropeanSpallationSource/epics-twincat-ads). The programme runs correctly.
  When I switched to another Beckhoff PLC, I then used BeckhoffADS module (https://github.com/EuropeanSpallationSource/epics-twincat-ads/BeckhoffADS)to test the connected PLC as follows:
# Authorise my ADS client for the TwinCAT target by adding an AMS route.
# Switching directories
cd example/
# build
make
# and run the example
make test
The following error occurs:
[newuser@localhost example]$ make test
./example.bin
Running step 1
Running step 2
What can I do to fix this?Thank you for your time.
Re: Beckhoff ADS to EPICS Torsten Bögershausen via Tech-talk
Beckhoff ADS to EPICS Lesley via Tech-talk
Prev: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) Michael Davidsaver via Tech-talk
Next: Re: Beckhoff ADS to EPICS Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Beckhoff ADS to EPICS Torsten Bögershausen via Tech-talk
