1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Beckhoff ADS to EPICS
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Lesley <[email protected]>
Date: Mon, 27 Nov 2023 06:14:29 +0100
Hej Lesley,
Out from the distance it is impossible to see what is wrong,
given the information I have.
_ The key for failing can be seen in this line:
_
_
_
_2023-11-24T19:33:57+0800 Info:connection closed by remote _
And out of my experience, it may be a missing ADS route.
Or a typo somewhere, so that you think that everything is
good, but the PLC does not (and closes the connection)
*Date: *Sunday, 26 November 2023 at 16:19
*To: *Torsten Bögershausen <[email protected]>
*Cc: *"[email protected]" <[email protected]>
*Subject: *Re: Beckhoff ADS to EPICS
Yes, I set up an ADS route on " another Beckhoff PLC " as follows.
First of all  I used BeckhoffADS module (https://github.com/EuropeanSpallationSource/epics-twincat-ads/BeckhoffADS)to test the connected PLC. I set up the new ADS route in the following file in this module.
BeckhoffADS/PLC-TestProject/NotificationTest.tsproj
BeckhoffADS/example/example.cpp
Then I execute make test and the following error occurs.
./example.bin
2023-11-24T19:33:57+0800 Info: Connected to 192.168.3.10
Running step 1
_2023-11-24T19:33:57+0800 Error: read frame failed with error: 104_
Add device port: 0x851
_Add device notification failed with: 1861 _
Running step 2
notificationByNameExample():
make: *** [test] Broken pipe
What is the cause of this error?
Also, for the IOC, I changed the AmsId and IP of another PLC in the file "startup/adsOnlyIO.cmd".
At 2023-11-24 23:44:55, "Torsten Bögershausen" <[email protected]> wrote:
   Hej Lesley,
   Did you set up an ADS route on “another Beckhoff PLC“ (towards your
   IOC ?)
   /Torsten
   Lesley via Tech-talk <[email protected]>
   *Reply to: *Lesley <[email protected]>
   *Date: *Friday, 24 November 2023 at 16:21
   *To: *"[email protected]" <[email protected]>
   *Subject: *Beckhoff ADS to EPICS
   Hello!
   I previously used the EPICS Module to communicate with TwinCAT
   controllers over ADS protocol
   (https://github.com/EuropeanSpallationSource/epics-twincat-ads). The
   programme runs correctly.
   When I switched to another Beckhoff PLC, I then used BeckhoffADS
   module
   test the connected PLC as follows:
   # Authorise my ADS client for the TwinCAT target by adding an AMS route.
   # Switching directories
   cd example/
   # build
   make
   # and run the example
   make test
   The following error occurs:
   [newuser@localhost example]$ make test
   ./example.bin
   Running step 1
   Running step 2
   What can I do to fix this?Thank you for your time.
Beckhoff ADS to EPICS Lesley via Tech-talk
Re: Beckhoff ADS to EPICS Torsten Bögershausen via Tech-talk
Re: Beckhoff ADS to EPICS Lesley via Tech-talk
Prev: Re: Beckhoff ADS to EPICS Lesley via Tech-talk
Next: Re: PiezosystemJena NV40/3 CLE Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Carsten Winkler via Tech-talk
