1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Adding additional fields to be archived in "policies.py"
From: Timo Korhonen via Tech-talk <[email protected]>
To: Gerrit Kühn <[email protected]>
Cc: Michael Davidsaver via Tech-talk <[email protected]>
Date: Fri, 6 Sep 2024 09:42:15 +0000
In that case I would say that the plugin should be enhanced to be able to get the status and severity fields. As I wrote, I am not familiar with the plugin so I cannot say how difficult that would be.
The important point is that the severity and status are "atomically" included in the data samples. If you pick them up as separate PVs, then you have to do (non-trivial) data sorting to figure out when the severity & status have changed.
Timo
On 2024-09-06, 11:28, "Gerrit Kühn" <[email protected] <mailto:[email protected]>> wrote:
Am Fri, 6 Sep 2024 09:09:18 +0000
schrieb Timo Korhonen <[email protected] <mailto:[email protected]>>:
> This does not rely on HIGH, HIHI, etc., but is shown in the severity
> field in the archived data.
> I think that should do what you need - as far as I understand correctly.
> I am not familiar with the archiver datasource plugin though.
Unfortunately we did not find a way (so far) to access alarm status or
alarm serverity fields via the plugin. We can request data from PVs and
work with that (and set up alerts based on the data), but there is no
obvious way to access the other fields (unless they are "archived fields"
like HIHI etc.).
Maybe the plugin doesn't support this? In that case would could probably
fall back on creating an extra channel per device that reflects the error
status. Or would the first idea we had (simply adding PVNAME.STAT
explicitely to the archiver) work as well?
cu
Gerrit
Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
Adding additional fields to be archived in "policies.py" Windsor Tanner via Tech-talk
Re: Adding additional fields to be archived in "policies.py" Michael Davidsaver
Re: Adding additional fields to be archived in "policies.py" Timo Korhonen via Tech-talk
Prev: Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
Next: Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
