1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Adding additional fields to be archived in "policies.py"
From: Gerrit Kühn via Tech-talk <[email protected]>
To: Timo Korhonen <[email protected]>
Cc: Michael Davidsaver via Tech-talk <[email protected]>
Date: Fri, 6 Sep 2024 11:53:42 +0200
Am Fri, 6 Sep 2024 09:42:15 +0000
schrieb Timo Korhonen <[email protected]>:
> In that case I would say that the plugin should be enhanced to be able
> to get the status and severity fields. As I wrote, I am not familiar
> with the plugin so I cannot say how difficult that would be.
> The important point is that the severity and status are "atomically"
> included in the data samples. If you pick them up as separate PVs, then
> you have to do (non-trivial) data sorting to figure out when the
> severity & status have changed.
Thank you for this thorough explanation. Looking at the plugin's issue
page, I just found this (maybe I should have looked there earlier and not
trusted Google that much):
https://github.com/sasaki77/archiverappliance-datasource/issues/156
So the author is already aware of the issue.
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Adding additional fields to be archived in "policies.py" Windsor Tanner via Tech-talk
Re: Adding additional fields to be archived in "policies.py" Michael Davidsaver
Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn
Re: Adding additional fields to be archived in "policies.py" Timo Korhonen via Tech-talk
Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
Prev: Re: Adding additional fields to be archived in "policies.py" Timo Korhonen via Tech-talk
Next: Re: Adding additional fields to be archived in "policies.py" Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
