1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Adding additional fields to be archived in "policies.py"
From: Timo Korhonen via Tech-talk <[email protected]>
To: Gerrit Kühn <[email protected]>
Cc: Michael Davidsaver via Tech-talk <[email protected]>
Date: Fri, 6 Sep 2024 10:34:52 +0000
Hi again,
> Maybe the plugin doesn't support this? In that case would could probably
> fall back on creating an extra channel per device that reflects the error
> status. Or would the first idea we had (simply adding PVNAME.STAT
> explicitely to the archiver) work as well?
In the meantime, until the requested feature is available in the plugin, you can of course use your first idea. That should work, albeit with the caveats that I mentioned earlier (non-atomicity).
Adding an extra channel (=record) should not be necessary.
Timo
Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
Adding additional fields to be archived in "policies.py" Windsor Tanner via Tech-talk
Re: Adding additional fields to be archived in "policies.py" Michael Davidsaver
Re: Adding additional fields to be archived in "policies.py" Timo Korhonen via Tech-talk
Prev: Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
Next: OPCUA v0.10: full support for open62541 SDK client Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
