1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Help understanding DTYP Soft Timestamp
From: Marco Filho via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 18 Oct 2024 13:52:31 +0000
Hello all. Today I came across this interesting record:
record(stringin, "$(P)$(R)customTimeTimestampIn") {
    field(DTYP, "Soft Timestamp")
    field(SDIS, "$(CUSTOM_TIMESTAMP) CP MS")
    field(DISV, "-1")
    field(TSEL, "$(CUSTOM_TIMESTAMP).TIME CA")
    field(INP,  "@%s.%f")
It's a record meant to get the timestamp from another record via CA.
I had never seen the Soft Timestamp DTYP before. After digging a while I found some e-mails on tech-talk
https://epics.anl.gov/tech-talk/2020/msg01593.php
But couldn't find the documentation on how to use this. Is there any specific link I should look for?
Thanks in advance,
Marco
Re: Help understanding DTYP Soft Timestamp Johnson, Andrew N. via Tech-talk
Prev: Use EPICS 7.0.* in production? J. Lewis Muir via Tech-talk
Next: Re: [Ext] RE: Help setting up coordinated motions for Galil controller Jesse Hopkins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: Use EPICS 7.0.* in production? Johnson, Andrew N. via Tech-talk
Next: Re: Help understanding DTYP Soft Timestamp Johnson, Andrew N. via Tech-talk
ANJ, 18 Oct 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
