Hi Marco,
The part of that record which copies timestamps is the TSEL link pointing to the .TIME field of the record whose timestamp you want to copy. There is documentation for the TSEL and related TSE fields here, hope this helps:
- Andrew
__
Complexity is free, you pay for Simplicity
From: Tech-talk <[email protected]> on behalf of Marco Filho via Tech-talk <[email protected]>
Sent: Friday, October 18, 2024 9:52:31 AM To: [email protected] <[email protected]> Subject: Help understanding DTYP Soft Timestamp Hello all. Today I came across this interesting record: record(stringin, "$(P)$(R)customTimeTimestampIn") {
field(DTYP, "Soft Timestamp") field(SDIS, "$(CUSTOM_TIMESTAMP) CP MS") field(DISV, "-1") field(TSEL, "$(CUSTOM_TIMESTAMP).TIME CA") field(INP, "@%s.%f") } It's a record meant to get the timestamp from another record via CA. I had never seen the Soft Timestamp DTYP before. After digging a while I found some e-mails on tech-talk https://epics.anl.gov/tech-talk/2020/msg01593.php But couldn't find the documentation on how to use this. Is there any specific link I should look for? Thanks in advance, Marco
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
