1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: [Ext] RE: Help setting up coordinated motions for Galil controller
From: Jesse Hopkins via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Fri, 18 Oct 2024 10:08:47 -0500
Hi Mark,
Thanks for the clarification!
All the best.
- Jesse
Jesse Hopkins, PhD
Deputy Director
BioCAT, Sector 18
Advanced Photon Source
On Thu, Oct 17, 2024 at 7:44 PM Mark Clift via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi Jesse,
Yes, when moving a GalilCSAxis (not jog), backlash and retries are supported on both the GalilCSAxis and the GalilAxis that are members of the GalilCSAxis group.  Both GalilCSAxis and GalilAxis have an associated motor record.  If backlash and retries are enabled on both the GalilCSAxis and GalilAxis members, it could be doubling up somewhat (redundant).  Recommend having backlash and retries set on either the GalilCSAxis or the GalilAxis members (if required at all), but not both.
For both GalilCSAxis and GalilAxis, backlash and retries can be configured through the motor record as normal.  Retries can be turned off by setting the appropriate motor record RTRY field to 0.  Backlash can be turned off by setting the appropriate motor record BDST field to 0.
An implementation detail is that GalilCSAxis move completion is held up until the GalilAxis members complete.  This means, all the member GalilAxis will set their DMOV 1 first, and the GalilCSAxis will set it's DMOV 1 last.  The move completion rule only applies for CSAxis moves.
Kind regards,
Mark Clift
Re: [Ext] RE: Help setting up coordinated motions for Galil controller Mark Clift via Tech-talk
Prev: Help understanding DTYP Soft Timestamp Marco Filho via Tech-talk
Next: Re: Help understanding DTYP Soft Timestamp Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: [Ext] RE: Help setting up coordinated motions for Galil controller Mark Clift via Tech-talk
Next: Phoebus: how to lock split panels size Alessandra Palazzo via Tech-talk
ANJ, 18 Oct 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
