Hi Lewis,
No, the version numbering system evolved again when we released EPICS 7 and the online documentation hasn’t kept up to date with every aspect of the changes.
You could state that EPICS 7 has never reached production quality because we haven’t updated the documentation enough to describe it fully, but in that case it
will probably never make it as the Core Developers have prioritized fixing bugs and adding features over updating every individual online page of documentation.
- Andrew
__
Complexity is free, you pay for Simplicity
From: Tech-talk <[email protected]> on behalf of J. Lewis Muir via Tech-talk <[email protected]>
Sent: Thursday, October 17, 2024 10:37:59 PM To: EPICS Tech-Talk <[email protected]> Subject: Use EPICS 7.0.* in production? Hello, Tech-Talkers!
Is EPICS 7.0.8 a developer release that should not be used in production? I ask because at https://urldefense.us/v3/__https://epics.anl.gov/base/index.php__;!!G_uCfscf7eWS!ZTt7qznz4xlCwL0cLoMwgMnloSX9BTr-0EiUhx6uKrAeLVJE-vulKmvU6Lz7yyvTTtamLbmUGhW-AjdXhDOBZg$ it says in the "Versions and Numbering" section: The EPICS Version numbering system has evolved over the years so older version numbers may not mean quite the same thing as more recent ones, but any version with a zero component in the number such as 3.15.0.1 was a developer release and should not be used for production systems. The first release in the 3.15 series that qualified for production use was version 3.15.1. Since EPICS 7.0.8 has a zero component, does that mean it is a developer release that should not be used in production? Or is the wording of the above not quite right, and what it really means is that there can be a zero component in the series name (e.g., "7.0"), and only if there's a zero component outside of the series name in the version (e.g., "7.0.0.1") is it a developer release? Thanks! Lewis
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
