1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: EPICS Support for NI-9223
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: Abdalla Ahmad <[email protected]>
Date: Thu, 15 May 2025 10:33:58 +0000
Hi Abdalla,
The module just depends on the NI DAQmx library and EPICS asyn, the link you mention below should give you the necessary DAQmx C library to use. We have only ever used this on Windows ourselves, we do have a linux RHEL9 build server but I notice we currently exclude building this module there at the moment. I can give building it there a go and also tidy up our support module a bit as I think it looks to include some unnecessary other parts of our system, I can probably get that done by sometime tomorrow inbetween other things I am doing
Freddie
Sent: Thursday, May 15, 2025 10:08 AM
To: Freddie Akeroyd - STFC UKRI <[email protected]>
Hi Freddie
Thanks for the link, I am not familiar with NI ecosystem so I have few questions:
  1. Any prerequisites for building this support?
  2. In this downloads page https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#565431 there is a section for Linux downloads, does this download provides an API that I can use to build an EPICS driver on Linux or is it Just a LabVIEW instrument driver?
Thanks!
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
From: Tech-talk <[email protected]> On Behalf Of Freddie Akeroyd - STFC UKRI via Tech-talk
Sent: Tuesday, May 13, 2025 4:39 PM
To: EPICS Tech Talk <[email protected]>
Hi Abdalla,
We made a fork of the original EPICS DAQmxBase software and adapted it for DAQmx on Windows – the code is at https://github.com/ISISComputingGroup/EPICS-DAQmxBase
Freddie
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: 13 May 2025 09:45
Subject: Re: EPICS Support for NI-9223
On Tue, 13 May 2025 at 09:58, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
I noticed on the NI section of EPICS manufacturers page https://epics.anl.gov/modules/manufacturer.php#National%20Instruments there is an EPICS driver for the NI-DAQmx interface which, according to NI website, works with the NI-9223 but the SVN URL ( http://epics.svn.sourceforge.net/viewvc/epics/applications/trunk/DAQmxBase/ ) is not working. Is there another URL to clone the driver? Will this driver work with the NI-9223? Are there other alternatives?
FWIW, the modules database has moved to https://epics-controls.org/resources-and-support/modules/ a few years ago.
Note that DAQmx and DAQmx Base are two different NI software products. DAQmx Base development was frozen by NI in 2019 (last release: 2015).
ITER has plain EPICS support and an NDSv3 device driver for the IRIO library (by the I2A2 institute of UPM - University of Madrid) on top of the NI DAQmx open source driver (yet another NI driver). [1]
The first official release of the IRIO-based stack was also announced on Tech-Talk [2] and later reported in the EPICS Collaboration Meeting in June 2019. [3]
NDSv3 is the C++ framework for data acquisition that ITER proposes for its diagnostics use cases. It was presented in more detail at the ICALEPCS 2021. [4]
We're currently in the middle of the procedure to make the ITER developments for NDSv3 public. Once we have the authorization, things will appear on GitHub.
Cheers,
~Ralph
EPICS Support for NI-9223 Abdalla Ahmad via Tech-talk
Re: EPICS Support for NI-9223 Ralph Lange via Tech-talk
RE: EPICS Support for NI-9223 Freddie Akeroyd - STFC UKRI via Tech-talk
RE: EPICS Support for NI-9223 Abdalla Ahmad via Tech-talk
Prev: RE: EPICS Support for NI-9223 Abdalla Ahmad via Tech-talk
Next: Re: Area Detector manta camera communication issue Pratt, Linda (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: FW: EPICS Support for NI-9223 Mariano Ruiz via Tech-talk
