1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: String manipulation from IOC Output
From: Dariush Hampai via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 26 May 2025 16:26:28 +0200
Dear all,
after a big help from Mark and Maurizio, I developped the IOC of an Ortec 994 with card 99X-1 for serial interface.
In my github page who need can download the sources.
https://github.com/Teclis77/Ortec-994
Thanks to all
Dariush
Il 22/04/2025 20:12, Dariush Hampai ha scritto:
Dear all,
I’m developing an hardware IOC for NIM Ortec chain, with Ortec 994 Dual Counter and RS232 99X-1 card interface).
Following the examples and tutorials, I wrote a db and a proto files where I included the call functions. One of them is the SHOW Count function, that gives the following answer (via telnet)
SHOW_COUNT
0000000;0000000;
%0000069
The first answer are the two channels counts, while the second one is the Counter has properly answered and it is ready.
My proto files contains the following call for simple read the display (SH_COU is the abbreviation of SHOW_COUNT)
getCount {
        out "SH_COU";
        in "%s";
and for starting count
setStart {
        out "START";
        in "%s";
        wait = 1500;
        out "SH_COU";
        in "%s";
        ExtraInput = Ignore;
        out "CL_COU";
        in "%s";
        out "STOP";
        in "%s";
In the same proto file I define the display (0 or 1 for display A or B)
setDisplay {
        out "SET_DISPLAY %s";
        in "%s";
        @init {
                out "SET_DISPLAY 0";
                in "%s";
The question is: how can I read only the display A or display B (depending on setDisplay) if the outpuit is “ 0000000;0000000;
Thank you in advance
Dariush
p.s.: I know that in Scaler module there is already am Ortec974 module, but the cpp file is optimized for that nim module (4 channels) and for GPIB communication, while my ortec994 is serial through MOXA NPORT converter (RS232 to IP), so I should modify too much the sources.
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
String manipulation from IOC Output Dariush Hampai via Tech-talk
Prev: No motor ui in pydm l123173 via Tech-talk
Next: Re: Process PINI-Record again as soon as device is reconnected Dr. Simon Friederich via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: String manipulation from IOC Output Dariush Hampai via Tech-talk
Next: ICALEPCS'25 in Chicago! Abstract submission and registration now open for the 20th International Conference on Accelerator and Large Experimental Physics Control Systems Johnson, Andrew N. via Tech-talk
