1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: [EXTERNAL] Re: Anyone using Zaber motion controllers
From: "Pearson, Matthew via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 7 Nov 2025 14:29:38 +0000
Hi Ralph,
Based on the answers so far, I will go with:
"Looks like a reasonable device choice. Use the ASCII protocol. Based on the functionality you need, start with StreamDevice and/or write a type 3 motor support if that fits better. Try to avoid the Motion Library as introducing a new programming language would need strong justification."
That’s what I’d do as well, especially for a one-off single axis system. streamDevice first (optionally also with a soft motor record interface), then perhaps a motor driver later (ASCII based, one that doesn’t rely on a vendor supplied library).
Cheers,
Matt
Anyone using Zaber motion controllers? Ralph Lange via Tech-talk
Re: Anyone using Zaber motion controllers? Laurenz Rettig via Tech-talk
Re: Anyone using Zaber motion controllers? Torsten Bögershausen via Tech-talk
Re: Anyone using Zaber motion controllers? Wlodek, Jakub via Tech-talk
RE: Anyone using Zaber motion controllers? Pearson, Matthew via Tech-talk
Re: Anyone using Zaber motion controllers? Ralph Lange via Tech-talk
Re: Anyone using Zaber motion controllers Torsten Bögershausen via Tech-talk
Re: Anyone using Zaber motion controllers Ralph Lange via Tech-talk
Prev: Re: Anyone using Zaber motion controllers Ralph Lange via Tech-talk
Next: Re: Tech-talk Digest, Vol 19, Issue 496 miqingru--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: RE: [EXTERNAL] Anyone using Zaber motion controllers? Pearson, Matthew via Tech-talk
