2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record support and user-defined fields
To: [email protected]
Date: Tue, 12 Jul 2005 06:41:57 -0500
Benjamin Franksen wrote:
On Monday 11 July 2005 14:55, Marty Kraimer wrote:
Also templates should not appear in the DBD files. This can be done
by properly defining interfaces which are implemented by "record
fragment".
Hmm. Can you explain how, for instance, an 'invalidOutput' struct can be specified in the DBD so that it is usable as building block for stringout as well as ao record type, without parameterizing over the type of the value?
I did not express myself properly.
It is not the templates but the methods that should not appear in the DBD files.
There should not be ANY language specific definitions in DBD or DB
files.
Note, in my original proposal (on the wiki), there is not a single mentioning of a C or C++ language feature in the DBD file. If you insist, I can write down a precise and self-contained definition of the meaning of the angle-brackets notation I used in the DBD fragments I posted.
Ben
The following shows a way to handle code fragments just like device support.
1)NO METHODS appear in the dbd file.
2) It uses Andrew's suggestet syntax for templates.
3) It uses a device definition
A dbd file contains the following:
menu(invalidAction) {
   choice(invalidActionContinue_normally,"Continue normally")
   choice(invalidActionDon_t_drive_outputs,"Don't drive outputs")
   choice(invalidActionSet_output_to_IVOV,"Set output to IVOV")
The record.dbd file contains
record(xxx)  extends iocRecord {
   field(invalidAction,menu(menuIvoa))
   field(outputValue,float64)
   field(invalidOutput,device(none,processInvalidOutput))
Also in a dbd file the following appears
   device(none,default,processInvalidOutput)
Some .h file contains:
   class processInvalidOutput {
virtual void compute(int32 value, DbfMenu &invalid,epicsString &status, epicsInt16 &severity); virtual void compute(float64 value, DbfMenu &invalid,epicsString &status, epicsInt16 &severity);
         ... // perhaps other types for value
The process routine then has a statement like
pprocessInvalidOutput->compute(outputValue,invalidOutput,,status,severity);
Thus code fragments are handled just like device suppoort that has no direction. For this example the device definition also has no dataStructName. Code fragments that need additional private data could define a dataStructname.
Marty
Re: Record support and user-defined fields Benjamin Franksen
V4 iocRecord: forward linking Ralph Lange
Re: Record support and user-defined fields Andrew Johnson
Re: Record support and user-defined fields Marty Kraimer
Prev: Re: Record support and user-defined fields Benjamin Franksen
Next: Re: Record support and user-defined fields Benjamin Franksen
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
