2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Redundancy Patch: iocsh
Cc: EPICS core-talk <[email protected]>
Date: Wed, 21 Nov 2007 10:06:47 +0100
Hi, Andrew,
It's OK now. Thank you very much!
Gongfa
Andrew Johnson wrote:
Hi Gongfa,
Ok, lets try moving those definitions to file scope since that's where all the others are found. As before, the following patch is against the original R3.14.9 file:
Index: iocsh.cpp
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/iocsh/Attic/iocsh.cpp,v
retrieving revision 1.9.2.35
diff -u -b -r1.9.2.35 iocsh.cpp
--- iocsh.cpp   12 Dec 2006 21:04:19 -0000      1.9.2.35
+++ iocsh.cpp   20 Nov 2007 23:28:31 -0000
@@ -142,15 +142,16 @@
  * Register variable(s)
+static const iocshArg varCmdArg0 = { "[variable",iocshArgString};
+static const iocshArg varCmdArg1 = { "[value]]",iocshArgString};
+static const iocshArg *varCmdArgs[2] = {&varCmdArg0, &varCmdArg1};
+static const iocshFuncDef varFuncDef = {"var",2,varCmdArgs};
 void epicsShareAPI iocshRegisterVariable (const iocshVarDef *piocshVarDef)
     struct iocshVariable *l, *p, *n;
     int i;
     int found;
-    static const iocshArg varArg0 = { "[variable",iocshArgString};
-    static const iocshArg varArg1 = { "[value]]",iocshArgString};
-    static const iocshArg *varArgs[2] = {&varArg0, &varArg1};
-    static const iocshFuncDef varFuncDef = {"var",2,varArgs};
     iocshTableLock ();
     while ((piocshVarDef != NULL)
Along with most of the rest of the US population, I will be on vacation for the remainder of this week.
- Andrew
Gongfa Liu                         MKS-2, DESY
phone:  +49-40-8998-1642           Notkestr. 85
fax:    +49-40-8998-4388           22607 Hamburg
e-mail: [email protected]         Germany
Re: Redundancy Patch: iocsh Andrew Johnson
Re: Redundancy Patch: iocsh Liu, Gongfa
Prev: Re: Redundancy Patch: iocsh Andrew Johnson
Next: Re: Redundancy Patch: db Liu, Gongfa
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Redundancy Patch: iocsh Andrew Johnson
