On 11/29/2017 02:07 AM, Dirk Zimoch wrote:
> I will try to implement something. My first attempt failed for the
> reason Andrew outlined. It is not possible to simply skip the all PVA
> modules for a specific T_A because at that time T_A is not yet defined.
> A flag needs to be checked inside every module.
It's even more complicated than that though; once we get Base to only
build the PVA modules for some target architectures and not for others,
how are the Makefiles in downstream modules such as AreaDetector
supposed to be set up to only build things that depend on PVA for
targets that have PVA built?
After thinking this over last night I now think it would be much more
complex and invasive than the original idea appears. It certainly isn't
going to be possible in the 7.0.1 release.
If you want to use EPICS 7, I think you will have to upgrade your
devices to run on a fully supported OS; partial support like this is
likely to be too invasive to be cost-effective.
- Andrew
- Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Ralph Lange
- RE: EPICS 7.0.1-pre1 -- vxWorks 6.2 Mark Rivers
- EPICS 7.0.1-pre1 Andrew Johnson
- Re: EPICS 7.0.1-pre1 Dirk Zimoch
- Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Dirk Zimoch
- Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Hartman, Steven M.
- Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Timo Korhonen
- Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Andrew Johnson
Re: SIML type CA and PINI=YES issue Kasemir, Kay
EPICS 7 vxWorks diff Dirk Zimoch
<2017>
2025
2026
<2017>
2025
2026
