There is a somewhat clumsy manual option. The modules subdirectory in the new structure is a drop-in place. If you clone core (without --recursive) and then manually check out only the submodules you want to build, the build does not need to be re-configured: it will always build all checked-out submodules. You can still develop, branch, merge in such a sparse source structure. It's certainly not automatically by target, but you might be able to get by with creating two workspaces: complete and classic. Each one would have the appropriate target configurations: those that can build everything or those that just support the minimal base. Cheers, ~Ralph On Wed, Nov 29, 2017 at 8:47 PM, Andrew Johnson <[email protected]> wrote: On 11/29/2017 02:07 AM, Dirk Zimoch wrote:
| ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
